Question about Ikelite 4035 Left Hand AF35 Auto flash kit with short tray Underwater Accessories Flash
I have purchased an Ikelite AF 35 strobe to use with my Sony DSC-TX1 camera and underwater housing. Even with the strobe set to the lowest setting, the photos I take with the camera set to 'housing on' are a whiteout. This strobe was recommended so I fear that I have something set up incorrectly. Can you help please.
    New Friend:
Xfv
Posted on Jul 04, 2011
    New Friend:
Akdenny, have an af35 myself and know from experience the issue is very likely to be the way you have the block out for the cameras flash. if you block it by having the tape inside the housing it confuses the af35 to fire at a higher setting. from what i can gather it senses the strength of the camera flash and adjusts. I get the best results with the blockout on the camera supplied diffuser, stops the flash camera going forward and gives plenty of light to get the af35 to fire right. to blockout i just use some black tape , fabric tape seems to stick well.
you will still need to set the auto level setting.
hope it works out, i find it a great flash. and the guys at ikelite very very helpful.
Posted on Dec 29, 2010
6ya staff
SOURCE:
How do I change autofocus points from nine to twenty-one
In the manual from page 62 and on, you see how to set.
You need the
25585492-ntsnzel2saiuiwmt1tdol4on-2-0.png and the
25585492-ntsnzel2saiuiwmt1tdol4on-2-2.png With the AF-area in the middle setting (Dynamic area AF) you can select 9, 21 , 51 focus points or 51 point 3D tracking.
The manual is still online for free here:
User Manual D300 Nikon Knowledgebase
Mar 17, 2015 | Ikelite Nikon D-300 Housing
What settings for underwater photos
Most camera's are not made to shoot under water. One of the most important things is an extended possibility for the white balance. Most DSC-T camera's only have some standard settings here, for daylight, cloudy and some light sources, like incandescent and fluorescent.
So even when you have a under water housing, you can't setup the camera for shooting under water. Sorry. Try a ruggedised camera, they are not that expensive and have everything you want.
Feb 25, 2015 | Sony Cyber-shot DSC-T10 Digital Camera
I cant get the strobe to fire. i cant even fire it for test i have full power and the lamp runs but nit the strobe. any sugestions?
This can be many things like the cord is bad, maybe a bit of corrosion on one of the ends or your hot-shoe is not connected all the way on the camera? Send back to Ikelite, if it's bad they will fix or replace.
Ikelite
50 W 33rd St.
Indianapolis, IN 46208
317-923-4523
Feb 27, 2011 | Ikelite SubStrobe DS-125 TTL
Tried my new Ikelite AF35 strobe for the first time today and had the disposable everready batteries (new) in for about 45 minutes. After taking some practice shots with the Nikon L22 camera in the new...
Sounds like an O-Ring problem, you need to use a bit of silicon when closing and O-Ring should be removed and cleaned after every dive. If the flash isn't working, you will have to send it in for service. Here is the address;
Ikelite
50 W 33rd St.
317-923-4523
Oct 17, 2010 | Ikelite 4035 Left Hand AF35 Auto flash kit...
Ttl auto does not work
Digital Camera Fully Compatible, Newly Developed S-TTL System "S-TTL" enables TTL auto shooting by an external strobe for a digital SLR camera as well as for a point & shoot digital camera.
INON S-TTL auto strobe supports any manufactures' model providing highly accurate exposure control.
Film camera era without strobe selection problem TTL stands for "Through The Lens" and TTL auto strobe system controls flash amount to provide correct exposure based on calculation by camera's internal sensor metering reflecting strobe light from a subject through the lens. This TTL system meters actual light amount reflecting from a subject providing accurate exposure.
When we start with the history of underwater TTL auto strobe, underwater camera?"NIKONOS V" released in 1984 was the first to provide automatic TTL flash control for underwater strobe SB-102, SB-103 succeeded by NIKONOS V compatible underwater strobes form other manufactures. The 5 pin electrical sync connector for NIKONOS V is most popular and widely adopted to connect an underwater strobe and underwater film camera (underwater camera/housing).
A film SLR camera has flexibility to select an underwater strobe. As far as housing has NIKONOS type electrical sync connector and properly wired, automatic TTL flash control is usable with any TTL auto strobe like Nikon SB-105, INON Z-220, Z-22 connected via electrical sync cable.
NIKONOS type 5 pin electrical sync connector and NIKONOS V with INON Z-22 strobe
Film camera compatible strobe is not usable for a digital camera!? Underwater TTL strobe circumstances have been drastically altered with the spread of digital camera among divers. Some underwater housing for digital SLR camera has NIKONOS type electrical 5 pin sync connector as same as film camera housing. Since the housing has same NIKONOS type sync connector, existing film camera compatible underwater strobe has been considered compatible with a digital SLR camera via 5 pin sync cable but happened to experience error message on the digital camera or blackout on an image even the strobe worked. Why this happened?
This is because automatic TTL strobe system difference between a film camera and a digital camera.
The film TTL auto system makes single flash while digital TTL auto system employs pre-flash type making two to three flashes. Film TTL auto strobe system starts firing at the same time the shutter opens and reflecting strobe light from a subject is recived at a film. The reflecting light on the film is metered by the sensor to determine when to cease firing for correct exposure. This process takes only about 1/1000 second.
In contrast, digital TTL auto strobe system can not calculate adequate exposure based on reflecting light from a subject since image sensor (CCD/CMOS) reflectivity is comparably low comparing to a film. So digital TTL strobe system gives preliminary flash for very short period of time (pre-flash) just before the shutter opens metering reflecting light from a subject by the sensor to calculate necessary amount of light for correct exposure and starts emitting main flash at the same time the shutter opens. Canon E-TTL and Nikon i-TTL employs this system.
When we connect conventional film camera compatible TTL strobe to pre-flash type digital SLR via sync cable, the strobe makes full dump by pre-flash signal then the shutter opens before the strobe has been fully charged resulting in quite under exposed image only with ambient light. Even two time flash compatible strobe like INON Z-220 strobe, does not fully support a digital TTL and force to use Manual flash mode.
Film SLR:
A strobe starts firing at the same time the shutter opens and quenches firing when correct exposure has been obtained.
A film compatible TTL strobe connected to a pre-flash type digital SLR via electrical cable flashes does not support TTL auto exposure resulting in synchronization only with first pre-flash or totally uncontrollable.
The birth of digital fully compatible S-TTL S-TTL auto compatible INON D-2000 strobe and Z-240 strobe works in TTL auto mode by simply setting their main dial to S-TTL position. A film camera seems to depend more on photographer's skill, experience and feel since the camera does not allow checking images on site. A digital camera allows us to check images right after shooting and enable to try to shoot again as much as we like. And high capacity memory card further allows to shoot hundreds of images. The digital camera makes entry level of underwater photography getting down and nowadays more people buy a digital SLR camera and underwater housing even they have just started underwater photography. However underwater photography gets more difficult because underwater strobe does not work in TTL auto.
INON is among the first to support digital TTL auto system with "S-TTL" auto mode equipped D-2000 strobe and Z-240 strobe.
The proper name of S-TTL is "Optical Synch TTL". S-TTL enables to perform in TTL auto exposure as same as genuine TTL strobe from camera manufacture, based on camera's built-in flash light to use as a signal to be transmitted to a strobe. S-TTL uses digital camera's built-in flash light not as a light source but as like a controller to trigger S-TTL strobe.
The built-in flash of a digital camera makes weak flash (pre-flash) before main-flash to calculate exposure. This pre-flash is transmitted to S-TTL strobe to control the strobe to make pre-flash to a subject. The reflecting light from the subject goes through the camera's master lens to an image sensor then a processor calculates main flash light amount for correct exposure.?Finally the built-in flash makes main-flash which is transmitted to the S-TTL strobe to cause main-flash of the S-TTL strobe.
Digital camera's built-in flash lights are transmitted via an optical fiber to the
S-TTL strobe to make pre-flash and main-flash instead of the built-in flash.
Apr 30, 2010 | Olympus FL-20 TTL Flash
HOW TO AVOID GET FOG ,CONDENSATION INSIDE THE HOUSING
Mothers rubbing compound gets rid of gunk on your head lights, and keep the plastic lubed up, get some silicone II "aviation glue" to create a tighter seal to keep; water from going in around the lights edge sondensation may still built up but on the inside
Dec 13, 2009 | Ikelite 6038.02 Underwater Video...
How is the strobe activated (ikelite A35)
It works from the flas on your camera. It will only sync to your camera as along as the ixus does have no pre flash feature.
Sep 23, 2009 | Ikelite Substrobe A35 w/ Arm and Tray f/...
Settings on my Nikon D-50
The Ikelite S100 is for a Canon Elph camera. I don't think you're going to get your D50 to work with it. If you have a 6805.1, which is designed for that model Nikon, your Owner's Manual is here:
http://www.ikelite.com/downloads/instructions/SLR_pdf/Nikon-pdf/Nik_D50.pdf
Did you buy the housing used? Did someone tell you it would work with your camera?
Dec 17, 2007 | Nikon D50 Digital Camera
DSC-P72 using Flash
Hi, While I do not have a P72, I find this problem odd. Most flash cycle times are so rapid that your grandaughter could not possible close her eyes in that time period (the travel time for the flash to fire and be reflected from the child's face is far faster than a human blink). The problem may be in pre-flash and not the flash itself. So that redeye-reducing "feature" may be responsible for your problem. Does your camera have a redeye reduction mode on the flash?
Sep 13, 2005 | Sony Cyber-Shot DSC-P72 Digital Camera
FD95 underwater housing?
2 ziplock bags and alot of duct tape (serious) itll be good down to about 10-20meters. It's limited use, but it works.
Sep 13, 2005 | Sony Mavica MVC-FD95 Digital Camera
Ikelite 4035 Left Hand AF35 Auto flash kit with short tray Underwater Accessories Flash Logo
230 people viewed this question
Top Ikelite Cameras Experts
Ekse
Marvin
Marvin
Are you an Ikelite Camera Expert? Answer questions, earn points and help others
