Question about Point 65 Tequila Kayak Center Piece
Point 65 tequila. is it possible to fix a rudder to this model as the nose wanders about when set up as a duo. ??
Posted by Thomas van Zoelen on
  • Thomas van Zoelen Feb 14, 2011
    Ok, have found the answer. went to a canoe shop and purchased a bracket that fits on the rear and a rudder. will adapt the bracket to fit the point 65
johan vandevelde
    New Friend:
I have build a skeg for the tequila and now it runs straight. i use it in Chichester harbour which is tidal and has a lot traffic on it. the kayak now runs like a dream,
Posted on Sep 10, 2013
  • 2 more comments
  • Bill
    Bill May 20, 2014
    Hello Johan!
  • Bill
    Bill May 20, 2014
    Can you tell how you fixed it? Can you post pictures? I do not dare to drill in the kayak itself... Thanks for you help!
  • Bill
    Bill May 20, 2014
    Add a Commentll
  • Bill
    Bill May 20, 2014
    Bill
Anonymous
    New Friend:
I have just bought a Tequila, and though I love it, I know what you mean. The problem is that the stern keel doesn't sit low enough when 2 people are on board. In duo config, with 1 person sitting aft, it handles fine, since the stern keel is more submerged.
I am working on a fixed rudder/skeg. Will post when I am successful.
Posted on Jan 08, 2011
    think I found a solution. went to a canoe shop purchased a fitting to hold a rudder to a canoe
  • Karen Dec 22, 2012
    Routier1642, did you solve the problem? I need to work out the same issue.. Thanks, Karen.
BrentFD
Tom6455, please let me know which rudder you purchased? I'd like to fix a rudder onto my tequila kayak.
Posted on Jul 05, 2012
  • Thomas van Zoelen Jul 06, 2012
    BrentFD the canoe shop had a rudder & bracket. I riveted this bracket to the hull and as I did not set up a foot operated steering system it became a fixed rudder. I then used cable ties to fix this rudder in the centre. had to make a few adjustements to the cable ties to centre it, but it now works. when not in use I flip the rudder up & use a stretch tie to hold it up. not sure if i can upload a photo but if u give me yr email i will send one. [email protected] cheers
    Tom, please post a pic. We have exactly the same problem with our point65 Tequila kayak when set up in two person configuration.. Thanks, Karen.
Loaded XPlane 10 on new iMac and rudder pedals no longer function?
My iMac has a CD/DVD drive, but I posted a X-Plane 10 pendrive to avoid inserting DVD #1 every session. It functions perfectly. Another point is to connect all peripherals (stick and pedals etc.) BEFORE launching X-Plane 10. Then calibrate your peripherals within XP 10.
I have no pedals set, but instead a pitch-stick with grip throttle and a Logitech joystick with twist grip to fly helicopters.
Jul 29, 2014 | Saitek Pz35 Pc Pro Flight Rudder Pedals
I AP 35 Setup
ensure you are setting correct rudder value.
Aug 14, 2008 | Simrad AP35 GPS Receiver
What is anejo tequila?
Anejo, meaning vintage, is aged tequila. This particular type of tequila is aged in oak barrels for a minimum of one year. This type of tequila is generally darker in color, smooth drinking and contain complex flavors.
Feb 05, 2013 | Wine & Spirits
What is tequila?
Tequila is a type of Mexican liquor made from an agave plant.
Are there different types of tequila?
Tequila is most often categorized in two ways - 100% Blue Agave and mixed Tequila. Mixed tequila's contain a minimum of 51% Blue Agave and the remaining 49% comes from other sugars, most often sugar cane.
What are some famous tequila based cocktails?
Tequila is more often served in the form of a shot, rather than a cocktail; however there are a few great cocktails made using tequila. I would recommend trying a margarita or a tequila sunrise.
Jan 10, 2013 | Wine & Spirits
Hi,Steve from Australia.I have a AP14H and am now having problems.The hand held is showing rudder angle hard to port.If I engage NAV the boat veers hard Port(even though the flagged waypoint is directly...
seems to be a problem with the rudder feedback sensor first check if rudder sensor is not mechanically disconnected,if not try to do de setup procedure,reset the unit to factory condition,try to set rudder limits,if this is not working ,check with other feedback unit.
Jun 26, 2010 | Simrad Ap14h Hydraulic Powerpilot
MOT POW SWAPPED, this is the message which appear just like that. the autopilot is working last 5 years, i have checked the wires connections, all is set as the diagram. one thing: my rudder has some...
Check if rudder reference unit is installed as before ,it seems that the pilot sense that the rudder is turning the wrong way. check when giving +10 command the
rudder turns to increase the heading,if yes, it could be the wiring of the rudder reference unit or it was installed the wrong way after service on the rudder.
Is rudder position indicating correctly?
Jun 24, 2010 | Raymarine Smartpilot Autopilot St6002 S1g...
Carolina rudder does not work properly
Slider to which the pegs are attached is probably binding, take entire mechanism out (2 screws), and lubricate with silicone wax. If that doesn't work, replace sliders and pegs.
Apr 06, 2009 | Carolina Manufacturing Perception Carolina...
AP35 Autopilot
Yep, if rudder calibration values are OK, then there is a real problem with calibration, it can be a mechanical problem or a faulty rudder feedback unit. Follow procedure at page 93 of user manual :
AP35 Autopilot Instruction Manualto troubleshoot the error, if you cannot get rid of the error message you may have to replace the rudder feedback unit or to have the unit inspected by a technician.
Point 65 Tequila Kayak  Center Piece Logo
1,486 people viewed this question
Top Point Boating Experts
ray gallant
Andrew Taylor
Andrew Taylor
Bill Boyd
Are you a Point Boating Expert? Answer questions, earn points and help others
