The problem with the gps device is a minor one. First you ensure it is properly charged, then you reset it by holding down the power button for about 15 seconds, then it will restart and you will be able to touch the screen once again. If that does not work, then you need to calibrate the screen, take note that calibrating the screen does not just work the moment you try it, you need to try it repeatedly till you get it right. This is how to calibrate your nuvi:
It is an easy fix. The solution above will help you out on that. Another solution is for you to remove the battery and fix it in back. That should also help.
Testimonial: "This was good, sound advice. It saved me $100.00 Thanks."
Your touchscreen should now be recalibrated.
If the screen is still not responding, then the unit will need to be replaced with a new unit at this time.
With Best Regards,
Benjamin B
Product Support Specialist
Automotive Team
Garmin International
913-397-8200
800-800-1020
913-440-8280 (fax) Att: Benjamin B, Associate #6891
Additional solutions may be found at http://www.garmin.com/garmin/cms/site/us/support/searchsupport
