Question about Fuji FinePix A330 Digital Camera
I have a Fuji FinePix A330 camera and when I try to take a picture in the light, daylight or lamp light, lines appear through the picture. Sometimes fine lines but other times like a burst of light. This just started happening recently. But when I take a picture in the dark with the flash the photo turns out fine. Any answer as to what caused this? Thanks
Posted by bacthafuc_up on
vasr36
    New Friend:
FUJIFILM AX330, LENS WILL NOT RETRACT
Posted on Sep 13, 2012
Anonymous
    New Friend:
I have a Fuji FinePix A330 camera and when I try Problem with the Fuji FinePix A330 Digital Camera I have a Fuji FinePix A330 camera and when I try to take a picture in the light, daylight or lamp light, lines appear through the picture. Sometimes fine lines but other times like a burst of light. This just started happening recently. But when I take a picture in the dark with the flash the photo turns out fine. Any answer as to what caused this? Thanks
Posted on Feb 11, 2011
1helpful
HOW DO YOU INITIALIZE PICTURE CARD FOR A FUJI FINEPIX A330 CAMERA
"initialize" means to format the card in the camera. This will erase it so download any pics first using a card reader if necessary. Then, with the card in the camera, go into the menu and find "format" or "initialize" and follow the on-screen instructions.
Is the firmware for fuji finepix A607 the same
Heres the support site for that camera - theres no firmware listed http://www.fujifilm.co.uk/consumer/digital/digital-cameras/legacy-cameras/finepix-a607-zoom/support I would not use the A330 firmware although considered identical - Its NOT it is identical to the A330, except for the fact that it uses a Super CCD sensor instead of the standard / conventional sensor in the A330...
why do you want to update the firmware ?
Camera will shut off when I try to take a picture
I think it can still be used for another month.. but you will spend a lot on batteries
Fujifilm finepix A330 switches off after trying to take a picture fitted 2 new 1.5v batteries,and an external power supply
The sliding lens cover is also the on/off...... be carefull you are not moving it as you take picture.
My camera takes pictures fine but pictures have horizontal lines
Sir,
This answer is regarding Fuji Finepix A330 pictures have horizontal lines this indicates camera is working fine but LCD screen is damaged.Kindly replace in nearest camera service center.
Usb cord not recognized...?
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Fujifine pix A330 produce blurred image on all picture taken
continuous blurred images? or only occasionally (say in low light)?
Fuji finepix A330
512 MB card problem
If the new 512mb xD card has a prefix of "H" or "M" before the 512, it is not compatable with your A330 unless a firmware upgrade is performed on the camera. You can download all the details here http://www.fujifilm.ca/x3720.xml
Wierd pictures
This is caused by a shutter that is stuck open. Normally the shutter closes right at the moment that you snap the picture and allows the image sensor to record what it saw at that moment. When the shutter does not close as intended the image sensor cannot properly record the image. This is why here are the lines across your images. The shutter can stick either due to an impact knocking the delicate blades off their tracks, or due to dust or moisture contamination sticking them open or closed. If gently tapping does not free them; the camera will require professional repair. David Millier Advance Camera Repair
Fuji FinePix A330 Digital Camera Logo
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
