Question about GE 25GT270 TV
Do the ge tvs have places for audio cords to hook up
Posted by angel_girly3 on
sonic boom electronics
  • 1,557 Answers
Most do there were installed in tv's in the early 80s and all tvs made after 1992 were fitted with r.c.a input video and audio
hope this helps
Posted on Dec 28, 2010
How do i hook up how do i hook up power source to ge washer
It should just plug in. should be a 120 volt power cord attached to the machine back. If its missing you need a power cord.
Vcr player won't work. Brand new unit.It's hooked up with Hdmi cord. Dvd will work. But for the vcr it says no signal
To connect the VCR to the TV use the far right VIDEO OUT, AUDIO (R for RIGHT, L for LEFT) jacks to connect to TVs VIDEO IN (yellow) and AUDIO IN jacks.
I lost my instructions for hooking my sound bar up to my new tv I ahd it hooked up to the last one and it worked now no sound and when I raise the volume it doesnt do a thing I programmed it to with m
Some sound bars have a seperate power cord, did you plug it in. Also, the source for the sound, are you using the audio outputs and not the audio inputs. They are all the same color (red and white) so you may have plugged in the wrong ones. If the sound bar is getting power, say a green led and the source for it is the tvs audio ouput jacks you might have to see if there is a seperate remote for the sound bar and raise the volume. Lastly the tvs audio output might have a seperate setting, it could be fixed or variable. Fixed will only change volume with the sound bar remote. In variable you will be able to change the volume with the tv remote but first you have to raise the sound bar level. Hope this helps in some way.
How to install DVD player on GE Model 19GT270 TV
To hook a DVD player to this model, you'll need an RF modulator (also called an RF converter). You can find one at most retailers where they sell TVs, and also online from places like Amazon.com.
Without the AV jacks, the only way the TV can pick up anything is with its tuner. An RF converter takes the audio and video signals from the DVD player and turns them into a channel 3 or 4 signal that the set can tune in. Unfortunately this does reduce the picture quality some, but on older TV sets it's the only option.
Does not have 3 color connections. Can you hook up a DVD player?
you must use the "Composite" video output (the single yellow plug, with the red/white for audio of course) of the DVD player. Tube TVs rarely have "Component" connections because they are primarily used for 480P and above resolutions, which tubers can't produce. If your TV and DVD player have "S-Video" connections, use them for the best possible picture.
My tv only has a cable hook up how do i hook a dvd player with red white and yellow cords
put the tv on av
#yellow cord in yellow socket
#red cord in red socket
#white cord in withe socket
now power the dvd
#Yellow cord in yellow socket
there will be 2 places for the red and white cords
#the red and white cords must be inserted in the audio,
# you will see them next 2 each other
insert them you it will work.
For More Info Email To [email protected]
Hooking up video game
you can not play that game on ch3-4 you have an audio/video plug on thhe back of tv you have to change the tv tv the a/v settig or on some tvs the game setting
The video/audio outlet port is busted
okay..... nobody else knew what to do so heres what i did and it works. i bought an rf modulator. i hooked it up to the tv, bypassing the original a/v ports (the modulator has new a/v ports) turned the tv on to the channel i selected on the modulator, and now i have audio and video again.... not sure why my video ports went out in the first place (on 3 tvs-see prior posting by me) but at least we can play games now without buying replacement tvs. good luck!
Need help connecting pc to tv.
on some tvs you can use the cord that goes from the cpu to the moniter and use the tv like a monitor but for tvs that cant use that cord u need some special cord that hooks the cpu up to the tv like you would hook up a PS2 or some other video game to a tv. If this doesn't work and u want help from other ppl i sugest u specify what tv and pc ur using and if u mean using the tv like a monitor or having the monitor and the tv hooked up to the cpu
GE 25GT270 TV Logo
Top GE Televison & Video Experts
 Francisco Mauricio...
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
