SOURCE: MyCurtis,Alpha-111S coffee machine isover filling the coffee pots
that model may have a digital timer that is acssed using the panal swithes get the number for wilbur curtis from thier web site they will talk you through it {simple} the other style timer is a potentiometer type To adjust first unplug brewer, look behind either the front panel or top cover for a dial with numbers around it. turn the dial down slightly brew a pot of water see where the water level comes keep turning down till desired level is reached
SOURCE: Is there any way to disable the automatic shutoff on drip coffee
mine decided to disable that function altogether, and it wont shut off unless I unplug it. Nice, safe piece of ****, Hamilton Beach!
SOURCE: Tim horton bunn coffee maker drips at the top of
Tim Horton bunn coffee maker is leaking from the bottom when I make a
brew of coffee .I notice the water is cold and not hot. is there any solution.
SOURCE: Bunn Coffee Filter Basket Tray Broken
If you will contact Customer Service at 800-263-2256 with the model and date code, they will be happy to help you. The tray assembling itself is not replaceable but the machine does carry a 3 year warranty.
SOURCE: i don't have a manual,
If you are using your machine everyday, it won't dry out. If you will call us at customer service at 800-352-2866 we can send you out a manual for your machine.
