SOURCE: Adaptec 2110S Driver for WIndows Server 2008
Windows Server 2008 is still a little new to get accurate drivers for it. Check on Adaptec.com and ask if they have a generic SCSI controller that will work for Windows Server 2008.
SOURCE: adaptec 29160n vista support issue
vista has a major issue with allowing even the admin to move and transfer files and folders.
I have run across a fix that helped me gain more control, but you probable need to get drivers for Vista from the scsi controler card manufacturer.
and for the drives.
Vista is a terribly restrictive OS.
WARNING: please do not do this if you can't reverse it on your own if needed. Editing your registry can be risky so use extreme caution.
if you follow this it helps.
Normal
0
MicrosoftInternetExplorer4
st1\:*{behavior:url(#ieooui) }
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Windows Vista Admin Hack
click start and run,
type in regedit
when Registry editor opens
click on HKEY Local Machine
click SOFTWARE
click MICROSOFT
click WINDOWS
click CURRENT VERSION
click POLICIES
click SYSTEM
HIGHLIGHT SYSTEM
in the area where there are values right click and select new/ DWORD
enter "EnableLinkedConnections"
press enter
right click EnableLinkedConnections and chose MODIFY and change the value to 1
Save and exit Registry Editor.
SOURCE: Hi.. please help... After installing scsci card im
Hi when you start the pc and goes to the scsi utilities and scans for device its not finding the device attached to it sioit gives you this message you can see if the terminator connect to the device is properly connected and its in its place ,also press CTRL+A to get into the adapter setting and in the scsi utilities section scan the devices if it finds it then check the id of the device how much its set to it should not be the same of the scsi card id .by default scsi card id is 7 but be sure.
SOURCE: I have successfully installed a
two things i would suggest in this case. 1- check that you have the latest bios for your card here. 2- check here for the latest drivers here and the compatibility list here.
