Unplug the fax machine and take out the backup battery if there is one, let the machine sit overnight, this might reset the processor IC back into normal operation.
The backup battery may need to be replaced "if you have one" it will cause similar problems if battery drops to low.The backup battery may need to be replaced "if you have one" it will cause similar problems if battery drops to low.
You can't post conmments that contain an email address.
At the door jam,check the condition of the pin switch. The switch may be cover with a boot.
Compare the condition of this pin switch to the working side.
Clean the general area and re-test.
AP position error will trigger a 6A00 error code. An error occurred in the AP motor during purging operation. According to the service manual you will need to replace the sheet feed unit, logic board assy, purge unit.
Problem
Why is CL ( or C ) flashing in the base message window?
Solution(s)
This indicates that you need to set the time and day on your answering system. During initial setup and any time there is a loss of power to the base, you will see this flashing indicator. Consult your User's Manual for instructions on setting the day and time. Manuals for most models can found on this site. Go to our MANUALS section, then search for your particular model.
