The compressor is running, that is a good sign. If you notice any cooling that is not a good sign. Even with the fan not running , the evaporator should have produce some cooling. Could it be that you are a condenser fan running? well, the compressor makes a distinct sound when it runs and you need to confirm that is running and not just the condenser fan.
Firstly- If you confirm that the condenser fan is running; that is, if there is one, that is good.
Secondly- Check and confirm that the compressor is running
Thirdly- If there is an evaporator fan inside the unit, check and confirm that is running.
If all checks okay and there is no cooling, the refrigerant might have escaped through a leak, and there will not be any cooling.
You can extrapolate from my troubleshooting steps to diagnose the wine cooler problem.
Good luck
Appliancewiz
Jacques
