Hitachi C10FR 10" Job-Site Table Saw 15 AMP Logo
Posted on Dec 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My husband lost the safety key for our Hitachi Table Saw Model Number C10FR. This saw is discontinued and the customer service department at Hitachi will not return phone calls or E mails. Can anyone give me any suggestions? We can not operate the saw without this, and we need to install laminate flooring.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 02, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1257
Points
I found Hitachi customer service to be quite helpful in replacing my safety switch for my C10RA2 table saw. My C10RA2 has a fixed metal stand, not the folding stand, and the part number for the red safety switch or key is 531-992R, while the switch itself is part number 314-459. If you have the folding stand the part number for the switch is 321-620 and the safety key is 321-621. Hitachi customer service in US: 1-800-706-7337. I am going to buy two or three! Almost lost a table saw over a cheap plastic part.
  • Anonymous May 02, 2012
Anonymous
Level 2:
Scholar:
  • Expert 127 Answers
  • Posted on Dec 28, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
127
Questions
0
Helped
181245
Points
364
The safety key comes with the rocker switch to turn the saw on/off. The rocker switch is part #726811 and sells for around $8-$10. You can check local tool parts suppliers or order online at sites like
http://www.ereplacementparts.com/rocker-switch-p-190059.html
2answers
Change blade without hitachi wrench
Which way do i turn the nut on the saw blade to change my blade? to me or away from me? looking at it from the front.
2helpful
I own a Hitachi 10CFR Table Saw. My question is: Can I load a Dado Stack onto the Arbor of this table saw to create a 3/4 dado cut? I've read everything from "Yes" to "Absolutely Not"...
After doing some research, I found that hitachi only recommends up to a 1/2 dado for this machine with most of the users agreeing that it probably does not have the stability or power to run a 3/4 inch safely. Meaning you probably can run the 3/4 but at you own risk.
3helpful
Can you run a dado blade on this saw?
The 15 amp 3 hp motor has plenty of power to handlee dado sets and you can purchase a dado blade insert for the saw on line from multiple resources
1helpful
My hitachi c10fr table keeps blowing the built in breaker everytime i turn it on---any suggestions
Check the motor housing and make sure it is not clogged with sawdust, that could bind the armature and cause it to over heat
My husband lost the set up instructions to his Hitachi table saw.
You can download the owners manual for all Hitachi products by going to http://www.hitachipowertools.com and selecting your product. Below is the link for the online pdf format owners manual for the saw in question.
http://www.hitachipowertools.com/product/files/saws/table_saws/C10FR_OM.pdf
I need the manual in Spanish to make the machine up .Where can I find one .This is Jobsite table saw C10FR THANKS
I just using an English / Spanish dictionary to translate it myself
Thank you for your reply
Silvia
1helpful
On my hitachi table saw mod. c10fr sounds like the bearing is bad
Went to their site and they don't offer just the bearings for the motor but sell as an assembly. If this tool is fairly new I would return if not what you can do is remove the motor and pull the armature with the bearings out and then go to a repair center and match them up. These bearings are numbered with a universal code so it should not be that hard. Let me know if you still need help and if I have answered your question would you please rate my response accordingly.
2helpful
Hitachi c10fr table saw wiring diagram
Here is a hand drawn diagram
Please rate this a fixya
Top Hitachi Saws Experts
Mike Cairns
Mike Cairns
Steve Pack
Steve Pack
john h
Are you a Hitachi Saw Expert? Answer questions, earn points and help others
