SOURCE: Resetting the lightbulb in my benq projector
press and hold exit button for 3 seconds or more and OSD will pop up, then follow instructions
SOURCE: BenQ MP610 password???
Hi, i have a problem with MP610 i lost password and i can give you the code num 22654 15072 7440 9690
SOURCE: BenQ MP610 Multimedia Projector Problem
I don't have the manual on this one, but in general if the lights indicated that the lamp needed to be changed because of hours of use, then until the lamp hours have been reset, the lights will remain. The owner's manual should have the procedure for resetting the lamp hours. Try that and update this if you still have a problem. Also, check to be sure that the lamp access door is closed completely. There are safety switches that get activated when the door is not installed correctly.
Dan
SOURCE: BENQ PROJECTOR
Mine needed a "fan module" replaced. The part number is 60.J8613.011.
Cost was $60, plus $100 for labour.
