Question about JVC DR-MX1S DVD Recorder/VCR
My VCR JVC DR-MX1 doesn't start up. I constantly have the message "loading" Even if I pull the power plug and try to restart I have no result
Posted by peter_vancan on
5 Related Answers
Anonymous
SOURCE: JVC DR=MX1
this happened to mine - could be that it is getting too hot (mine is in a cabinet) - turning the machine off (by unplugging the plug, not putting on standby) and letting it cool down seems to work.
However, the dvd has now stopped working (not related to the above problem) - hence me looking
Posted on Jun 21, 2008
Anonymous
SOURCE: I need a user manual for JVC DVD RECORD/VCR COMBO Model DR-MV1S
I got mine on-line, though I've forgotten where. Do a search using "JVC DR-MV1 manual". If all else fails, I could send you a copy, The pdf size is 8196 kb.
Posted on Feb 10, 2009
Edward Jennejohn
  • 244 Answers
SOURCE: JVC DR-MX1 loading error - how can I retrieve hard disk hdd conte
well, i sympathize with your problem- it may be a bit expensive, but there are 'data recovery' services available on-line. if the data on the hd is still intact, then they can either 'burn' it to dvds, or transfer it to an external, usb hd. then, if your pc has a dvd burner, you can archive the content to dvds! store them in hard case holders-make copies and store them in a safe place! fire-resistant safe, safe deposit box, with a trusted relative or friend, in case the originals become damaged. also, use the external to archive any future pictures, or videos- then back them up on dvds! would suggest 500GB-1TB usb 2.0 external,if your pc can support it! $85-150. cheap!
might send the external along with the 180MB to whatever service you decide to go with, that will save some $$, in the long run. (or it should- research what the recovery services offer!).
good luck!
Posted on Oct 04, 2009
  • 6197 Answers
SOURCE: jvc dvd/vcr player records from vcr to dvd but
Have you finalized the DVD in question? Unfinalized discs usually won't play in other machines. Is the DVD type compatible with the other dvd players? (Some may not handle DVD+R for example; it is an acceptable disc for the jvc DR-MV79.) Try a different brand and type of DVD. Check your other players supported discs.
To Finalize the disc, Menu > Setup > Disc Setting > Finalize (if needed set Disc Protection to Off).
I hope this helps.
Posted on Dec 25, 2010
Testimonial: "that was great so simple yet so important who knew you had to finalize after you told the dvd recording to finish "
bugoy31
bonifacio gomez
  • 1238 Answers
SOURCE: The JVC DR-DX5 unit constantly
Good day!
If your DVD is says loading every-time you power ON it.
You have to do is to power off the DVD and open the cover.Next,reset all connectors inside the player by disconnecting and connecting again.After that power it ON again to test if it is OK.
If the problem persist I think the hard disc is failure.
Please try that simple instruction and I hope this will be helpful.Thank you.
Posted on May 12, 2011
Jvc dr-mv100 won't eject dvd and doesn't sound like it's trying
Check and replace the CD loader mechanism. It is faulty. Do not loads CD onto reading deck properly.
Jun 06, 2012 | JVC DR-MV100B DVD Recorder/VCR
Hi I am trying to dub from a VHS tape to a DVD+RW disc and I get an error message "CAN NOT DUB WITH THIS DISC" I have tryed different disc and different brands and I still get the error message?...
a while ago many vhs tapes had a protection sceme to prevent copying, i forget the namee right now, "something" vision" i think. it may be the vhs and not dvd disc.
Jan 14, 2011 | JVC DR-MX1 DVD Recorder/VCR
good luck!
Oct 04, 2009 | JVC DR-MX1S DVD Recorder/VCR
Firmware crashed, unable to get repair in UK
I also have a faulty unit with discs that hadn't yet been finalised. You can access the discs via your PC. I used a program called IsoBuster by Smart Projects. There is a free demo which you can download. Just google it.
As for the faulty power supply, just scrap the unit and DON'T buy JVC again. Eventually, they will have to listen to the economies of scale.........
Sep 18, 2009 | JVC DR-MX1S DVD Recorder/VCR
Einschalten
Hallo
Ich denke bei Dir gibt es 2 Möglichkeiten.
1. Fehler auf dem Netzteil es müßtne 2,3 Kondensatoren gewechselt werden.
2. Die festplatte geht bei Mx1 häufig kaputt
Jan 10, 2009 | JVC DR-MX1 DVD Recorder/VCR
Digital reception
Hi
It is Impossibil.
ruud
Dec 03, 2008 | JVC DR-MX1 DVD Recorder/VCR
LG DVD/VCR COMBO MODEL LHCX247W
setting has been "burned" to prom for your region...accordianman
Feb 08, 2008 | JVC DR-MX1 DVD Recorder/VCR
JVC DR=MX1
Jan 13, 2008 | JVC DR-MX1 DVD Recorder/VCR
DVD Recorder stuck on "loading"
That's exactly the same problem as I have, any suggestions would be greatly appreciated. Used to solve it by turning off at the plug and restarting. Now won't load up at all though. I love the machine - when it works - it just isn't very often!
May 27, 2007 | JVC DR-MX1 DVD Recorder/VCR
JVC DR-MX1S DVD Recorder/VCR Logo
66 people viewed this question
Top JVC Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
