You need to switch the camera over to saving pictures directly onto the SD card.
- Menu
- Cam settings
- Chose AUTO or SD card option
- Press OK to SD card
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Once you have set the settings to save onto the SD card directly you might like to transferre your existing pictures from the internal memory onto the SD card:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card?
Answer :
Follow these steps:
On the camera, press Review and then Menu.
Select Image Storage.
Change to Internal Memory.
In the menu listing, scroll down to Copy, and select OK.
Select a single picture, or select All.
When you have finished copying pictures, reset the Image Storage location to your original setting.
What type of SD card are you using?
it is a SanDisk Ultra 8GB memory card
so it will delete then all the pics i took today.. that got saved to the built in memory even though there was an empty sd card in? hmm, sucks.
