? 7:06
https://www.youtube.com/watch?v=AvPv88SELXs
May 1, 2011 - Uploaded by donyboy73
Learn HOW TO REPLACE The Ignition Module in your StihlTS400 / TS420 ... I have a homelite 33cc Ranger it has no sparkat the plug but if I put a ... a good spark and there is fuel getting into the cylinder head also what are ...
Donyboy73, I hava a Stihl TS 420 and just replaced the pull rope (not sure what's ... a good spark and there is fuel getting into the cylinder head also what are your ..... Hi mate, i have no spark to my plug?? i have tried a brand new plug and still ...
66 results - HL Supply has the small engine ignition parts that will get your ... parts right here: ignition wires, chainsaw spark plugs, ignition coil sets, ... Please don't hesitate to contact us if you have any questions. ... Stihl TS400 (3-bolt old style), TS460 ignition coil with wire and cap ... Fits: Stihl TS410 and TS420 cut off saws
The box the coil came in should have a paper card for setting the gap. It isnt written on the paper....it is the paper! Put it between the coil and the flywheel and bolt it up! If there isnt a gap paper in the box use a paper business card in its place. The stock gap size of 0.0125 inches is virtually the same as the 12 point paper used for a business cards in the US. I would recommend checking spark before reassembly just to be sure everything is right. Be safe and good luck!
I've added the breakdown manual for you, have you replaced the fuel and air filters. could be a simple issue of not being able to draw up the fuel from the tank. Stone saws deal with a lot of dust and this seriously effects their running and also their cooling capabilities.
Power cutters run in a very dusty enviroment, if concrete dust passes the filter and enters the cylinder it will very quicky remove the plating on the cylinder and wear the piston skirt, once into the bearings it will destroy them, if the rings are badly worn ( remove them from the piston and check the end gap by entering them into the cylinder, if the gap is excessive you have had dust entering the cylinder )
where is the needle valve on stihl ts410
