Question about Palm LifeDrive Mobile Manager Handheld
Palm Life Drive won't boot up Just goes to Palm Splash Screen
Posted by gmax1948 on
2 Related Answers
hellonnnewma
DT
  • 26 Answers
SOURCE: palm lifedrive wont' boot stuck on palm screen
This sounds like the issue where the LifeDrive is stuck in a loop. You can see how to break the device out of the system loop on the Palm Knowledge Base article (26419) located HERE.
Hope that helps get you up and running again!
Posted on Sep 12, 2009
wardyorgason
  • 47 Answers
SOURCE: palm life drive frozen on "palm one "screen
When you see the first screen (the orange one) hold the UP button as the bar moves across the bottom of the screen. Let go right before the screen goes to the silver logo. If it continues and opens Prefs, then you need to delete the program causing it to reboot. If that doesn't work, do a Hard Reset. A Hard Reset will erase everything on your lifedrive, so only do it if you have to. Hold the Power Button while you push the reset button. Continue with the instructions to finish erasing your device.
Posted on Feb 20, 2010
Asus 1015cx will not boot at all
I would open it up, remove the hard drive and memory. Then see if you can get into the BIOS. Then put back the memory and try again.. Do you hear any beeps at startup?
Mar 08, 2014 | ASUS Eee PC 1015Cx
Blank screen after boot splash screen
Hi.
After you see the press Del and F12 message repeatedly tap the F8 key, see if that gets to the advanced boot menu, if it does select "Repair my Computer" from the list, and then follow the prompts. Have your Win 7 disk ready just in case you need it.
Let me know how you get on and good luck!!
Jan 02, 2013 | Computers & Internet
Once I turn on the laptop it stays stuck on the LG Splash screen, I press F2 to enter bios setup but it just stays on the splash screen, and nothing progresses, I can't do anything,
I've seen issues like this with a bad hard drive. When entering the bios it queries the hard drive first and it's got issues it can hang it up like this. If you have a spare try that. You can try to boot it without a hard drive to see if it gets past this. Some computers won't boot without a hd though. If you've got another computer you can look around online to make a flash drive bootable and use that instead of your hard drive. Lastly, get a new hd.
Oct 22, 2012 | Computers & Internet
Dell Dimension 4300 desktop screen goes black after windows splash screen appears. Have reseated RAM.
After hitting the power button on your computer, throw it into "BOOT MODE" and select your hard drive. See if this helps your computer load. If so, you will have to go into your BIOS Setup and make your current hard drive your Primary Boot Device.
If this doesn't help, load your restore disc and check your drive for errors.
Your problem shouldn't be anything more than a few registry errors OR a boot problem.
Sep 09, 2011 | Dell Dimension 4300 PC Desktop
It wont boot, goes to black screen with whit blinking dash
Yes, this sounds like the traditional black screen issue, but it's different! This machine is a Dell Dimension 3000 with XP. System won't boot. After Blue Dell BIOS splash screen with F2 & F12 options, it just goes black. There will ultimately be a white cursor in the upper left hand corner. I can edit BIOS with F2, I can get in to the boot menu with F12, but I can't do anything after that. I can even get in to the Safe Mode menu (F8), but it never boots.
Aug 14, 2011 | Gateway LT2001u Netbook
Gateway splash screen thats all I get
Try hitting the delete key over and over at boot up. If you can get to BIOS, you can disable the splash screen, and also make sure that the boot order is correct. Try to put your hard drive as first boot priority. Also, remove any CD's in the drives.
Good Luck.
www.cobaltflorida.com
Jan 20, 2010 | Gateway GT5242E PC Desktop
Acer aspire one after starting my laptop it goes to a black screen and says check cable connection..! PXE-E63: Error while initializing the NIC PXE-MOF: Exiting Intel PXE ROM. No bootable device-- insert...
The computer can't see the hard drive for one of many reasons.
1. Hard drive failure
2. Bad connection between hard drive and motherboard.
3. BIOS corrupted
4. Motherboard failure of HDD control.
Press F2 when the ACER splash screen appears and go into BIOS set up.
The first page should show the hard drive name and ID number.
This may be missing or have corrupted characters in it.
Go along to the 'save and exit' and allow a restart. This sometimes kicks it into life.
Replace the hard drive with a known good one and check to see if this is recognised in the BIOS.
Clean the contacts of the hard drive.
ACER fitted both types of hard drive to this model, either PATA (IDE) or SATA.
Dec 28, 2009 | Acer Aspire 5100 Notebook
My Computer won't but up- the fan goes, the lights blink on the keyboard but then the hard drive quits spinning. I suspect I have a virus. Can I do anything to fix this? I have a Norton Antivrus program...
You should see the HP logo splash regardless of any virus or what the Hard Drive is doing. Abscence of the splash screen at boot means something more essential, such as the power supply or a motherboard or processor is amiss. You may want to substitute another working power supply. Also inspect the large standup capacitors on the motherboard for swelled tops. If you see swelling then the caps have failed. Most people will look for a replacement motherboard when that happens, though the capacitors can be replaced. Replacement requires a 100 watt regulated soldering iron and good soldering skills, the capacitors themselves are not expensive.
If you are seeing the HP splash at boot, then your bios settings may have gotten corrupted (which you can set to the defaults to clear), or the Hard Drive may have a failure. To default the bios, hold the "delete" key at boot to enter the bios setup page. If you can enter the bios, load the defaults (typically F7) save and exit The system will reboot, and perhaps come back to life.
Nov 22, 2009 | HP Media Center M370N (DM163A#ABA) PC...
Palm lifedrive wont' boot stuck on palm screen
Sep 12, 2009 | Palm LifeDrive Mobile Manager Handheld
Palm LifeDrive Mobile Manager Handheld Logo
147 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
NOEL
NOEL
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
