Radio Shack Pro-97 Handheld Scanner Logo
Posted on Dec 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will the pro 97 receive Motorola Project 25 Phase (FDMA)?
Anonymous
Level 3:
President:
  • Master 2,761 Answers
  • Posted on Dec 28, 2010
Anonymous
Master
Level 3:
President:
Answers
2761
Questions
Helped
934109
Points
7369
NO. Sorry, but the PRO-97 is an analog trunking scanner, and it is not capable of receiving any digital signals. For more information on this scanner, you can download and print the factory manual, at no cost, here:
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/PRO-97_OwnersManual_ome20-527.pdf
Bill B.
Listening in since the 60's
Is this APCO-25 capable,the APCO-25 is the digital
No. The PRO-97 can receive both standard and trunked analog signals, but it is not digital capable. Also, there are no add-on boards or circuit modifications that can enable digital operation.
Bill B.
1helpful
Can I manually input the same frequencies from my pro 97 to a pro 2051 and receive the same audio as my 97? I know it would be time consumming, but can I do it? Thanks!
If I understand your question correctly, the answer is yes. The PRO-97 and 2051 cover the same frequencies and the same trunking systems, so you can program the same information into both. There is, however, no cloning capability between the two, so all programming will have to be done manually. Once it's done there is no way to synchronize the two units, so the chances of both receiving the same signal at the same time are remote.
I hope this answers your question.
Bill B.
1helpful
How can i get my pro 164 to pick up digital broadcast frequencies
Sorry, but your PRO-164 is an analog-only scanner. There's nothing you can do to or with it to receive and listen to digital transmissions. If digital systems are in use in your area you'll need a digital (APCO-25) equipped scanner to listen in to them.
Bill B.
Is the pro 2055 digital ?
The PRO-2055 is a versatile conventional/trunking scanner, but it does not have the capability to monitor APCO-25 digital transmissions. For an operating manual that is "Easier To Read" than the factory operating instructions, follow this link:
http://marksscanners.com/97/97.shtml#receive_modes
Bill B
Problem with PRO-2066 scanner not receiving local 800mhz Motorola trunk system II. It does trunk with the current data channels used (showing the ---- line) but I only hear transmissions on freqs ending...
It is difficult to explain in simple terms but I will try.
Google rebanding.
Some radios can have their firmware updated but I don't think your PRO 2066 can.
Channel numbers and frequencies preprogrammed into your scanner have changed over the past few years.
When a data signal says go to channel X that channel is now Y, but your scanner is still looking for X
Hope this helps
Pro-164 scanner stops receiving when Motorola talk-ids are progra
I had to buy the Radio Shack USB cable 20-047 and install
the driver for it and then I downloaded a program named
"Win97" from the www.starrsoft.com website as listed
on page 21 of the Pro-164 manual. The cable costs
$34.99 and with tax you are looking at about $37.88.
The "Win97" software must be registered for it to work
after a 30-day free trial period. That's approx $25.00.
This is the ONLY WAY to go !! You put in everything
on the software GUI and then upload it to the PRO-164.
Works like a champ !!!!!!
1helpful
3answers
Cisco VPN doesnt get connected through DI-524UP router. Worked fine until recently for both the laptops we use. Log indicates Receive: Purging stale cached fragment(s). Direct connected on the Motorola...
Cisco VPN
Upgrade your router to the latest firmware. You can download firmware at http://www.dlink.com.au/tech/ .
Disable all Firewall Software (ZoneAlarm, Windows XP Firewall, etc.).
Configuring PC running VPN Client Software:
Step 1 Disable all Firewall Software (ZoneAlarm, Windows XP Firewall, etc.).
Step 2 Change IP Address to be outside of the routers DHCP Pool (i.e. 192.168.0.99). By default the DHCP pool is 192.168.0.100 - 192.168.0.199.
Step 3 Configure Cisco VPN Client - Connection Properties.
Step 4 Check Enable Transparent Tunneling.
Step 5 Allow IPSec over UDP ( NAT/PAT).
Configuring Router using the Web-based configuration:
Step 1 Open the Web Configuration Page by entering 192.168.0.1 into your web browser. Enter username (admin) and your password (blank by default).
Step 2 Check the Status tab and make sure that you are running the latest version of firmware. If not, upgrade firmware before proceeding.
Step 3 Click on the Miscellaneous button on the Tools tab. Enable both PPTP and IPSec.
Step 4 Click Apply.
Step 5 Click on the Virtual Servers button on the Advanced tab.
Step 6 Enable IPSec from the list and configure as follows:
Private IP: IP Address of the PC running Cisco VPN Client
Protocol: UDP
Private Port: 500
Public Port: 500
Schedule: Always.
Step 7 Click Apply and then Continue.
Step 8 Enable PPTP from the list and configure as follows:
Protocol: TCP
Private Port: 1723
Public Port: 1723
Schedule: Always.
Step 9 Click Apply and then Continue.
http://www.dlink.com.au/tech/default.asp?model=DI-524UP
CAN MY RADIO SHACK PRO 97 HAND HELD SCANNER BE MADE TO RECEIVE DIGITAL SIGNALS?
The pro 97 is designed to receive analog signals. You will need to spring for a digital receiver if you want to go digital.
14helpful
2answers
Basic UPS system circuit diagram
i want to design 3-phase UPS system for my project. so, i need the basic UPS circuit diagram before doing this project....can anyone help me..where can i get the circuit i want 60kva to 200kva ups circuit diagram with block diagram
Top Radio Shack Radio Communications Experts
John
John
xxxxxx xxx
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
