Question about HP StorageWorks Computers & Internet
NO OS Stated, W10? or ?
ive no idea all your system topology, what networks.
sure sub net but what is it , consisting of what.??? vast choices.
we use wired Gigalan here 1000 bits/sec. wired. every inch.
all connected with GIGALAN high speed switches,
with wifi , all you are doing is doomed to failure (1 day ok day2, not)
i can list the top 100 reasons way, but will not.
ill do a few..., , collisions with neighborhood, or noise.
Channels are shared, and this is bad, in the concrete jungles.
WIFI is RADIO, and will fail with noise, near by. RFI its called.
google that. or wiki it. wifi is ok for chat ,email and whatsap.
iffy on, skype...
If WIFI is your mandate (bad) then move it to channel 10.
i use wifi radar app and move to where the other guys are not.!!!+
if wired tell me are you using reserved IP in DHCP of this unstated router. do so now.
make sure the media server is on a reserved IP .
then setup shares.
what are you serving
audio
video or both.
can you see the files using the" my computer icon" , called
windows Explorer?
"this PC" in 10 now.
just because you can ping it tells you only that the ping requests are honored there, and nothing else.,
it must have the shares all set correctly.
next time tell the help the lay out of your system
even post a system diagram.
be amazing but , rare here.
Posted on May 26, 2017
we have this nice program APP.
that we put on the server and on a workstation
it';s network testing app. end to end
it sends fast data back and forth between the 2. systems, end to end, it overloads the subnet on purpose.
it checks for errors and for low bandwidth
and more.
it works like the online speed tests you see.
but why better and is only on your subnet.
this is just one tool of many
try it?
PING proves little. (sure the target is partially alive sure (part of the 5 layer OSI stack is alive)
it's just this one command. here...
"Echo-request message" type8 code 0.
it's only a TCP-IP diagnostic mode.
you ping this out and the other echos back
it does not prove end to end communications at all. only the most lower layers. work.
Ping only checks raw ICMP socket,
this one line explains what it does.
" the ping program initializes, it opens a raw ICMP socket so that it can employ IP directly, circumvent-ing TCP and UDP" this tells All i need.
see that circumenting word, that means its not and end to end full test. not at all.
ever.
it's like looking at car in the drive way
PING, i see a car,
but does it drive?, who knows? not PING. or just looking at a car. parked.
PING IS ECHO, and proves only that the socket on the other end can see a ping and respond.
see RFC-792,
if you are really interested.
Apr 13, 2012 | Computers & Internet
Jun 27, 2017 | Ricoh Aficio 1035 Copier
May 04, 2011 | Sharp AR-M350N Copier
Check the network cable that connects the printer and the router. Please print a network set up page to check if the status shows connected under tcp/ip. To print a network set up page please click the link http://bit.ly/qTSoRt, please make sure that the correct print driver is installed on the pc.
Please take note of the IP address and type it on your browser
Apr 30, 2011 | Lexmark E120n Laser Printer
Sep 02, 2010 | Canon imageRUNNER 1023iF Black and White...
Jan 20, 2009 | Computers & Internet
Jan 02, 2009 | Computers & Internet
Dec 01, 2008 | Linksys Wireless-G WRT54GS Router...
Jun 24, 2007 | NexxTech NPCINIC Network Adapter
May 06, 2007 | 3Com OfficeConnect Wireless 11g 802.11g/b...
