1993 Toyota Previa Logo
Posted on Dec 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Heaters were not heating up machanic replaced water pump + thermastate and timing belt as radiator wasnt heating up now the water is boiling nut has not oil in it the oil level light is flashing but has no water in it and car is over heating
  • Mike Butler
    Mike Butler Dec 27, 2010
    I hate to ask a question when your looking for an answer, but I have to ask, did you call the mechanic who did the work? He's obviously done a few things wrong, and I'd give him a call to allow him to correct his mistakes first.
  • Anonymous Mar 17, 2014
    over heat
Anonymous
Level 2:
Sergeant:
  • Expert 242 Answers
  • Posted on Dec 27, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
242
Questions
Helped
115044
Points
766
There is 2 bleeders one can be accessed by the front of vehicle, the other if you lift the driver seat, if you do any coolant related job you have to open this bleeders during refill.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/flavio_517b938f50183b92
Anonymous
Level 3:
Genius:
  • Master 1,165 Answers
Anonymous
Master
Level 3:
Genius:
Answers
1165
Questions
0
Helped
383436
Points
3606
I don't understand why the timing belt was replaced for a heater problem. Is the car running rough or missing badly? Have you actually checked the oil or just relying on the oil level light. Check the oil and look for signs of water in the oil. If the oil doesn't show signs of water, refill the radiator with antifreeze and bring the oil level up to the full mark. Run the engine until it gets hot. Turn the engine off and let it cool enough so that you can remove the radiator cap. If the radiator is empty again, there must be leak somewhere. If you can't find a leak then it may be going inside the engine. If that is the case then the engine should be running very rough. Let me know what you find.
1helpful
Honda 2013 civic overheating.
Hope this helps, do this VERY Careful, when over heating Turn ON the heater to full, does it cool down? does the water in the Radiator Boiling?. = water pump, (don't always make noise).
Not boiling?- Check and R&R Heat sending Unit Gage on the Radiator or somewhere on the engine maybe close to the Thermostat..
1helpful
4answers
Waterpump 2002 ford turaus 3.0 durtec
3.0L Engine
VIN S Engine
  1. Before servicing the vehicle, refer to the precautions section.
  2. Drain the cooling system.
  3. Remove or disconnect the following:
  • Splash shield
  • Lower heater hose
  • Radiator lower tube bolt
  • Radiator upper front tube bolt
  • Air cleaner assembly
  • Battery and tray
  • Water pump belt
  • Upper radiator hose
  • Engine vent hose
  • Transaxle 10 pin connector
  • Radiator bypass hose assembly
  • Thermostat housing
  • A/C compressor brace, if equipped
  • Water pump mounting nuts
  • Connector hose
  • Water pump
To install:
  1. Install or connect the following:
  • Water pump
  • Connector hose
  • Water pump mounting nuts and tighten them to 15-22 ft. lbs. (20-30 Nm)
  • A/C compressor brace, if equipped, and tighten the nuts to 15-22 ft. lbs. (20-30 Nm)
  • Engine vent hose
  • Water pump belt
  • Battery and tray
  • Lower heater hose
  • Splash shield
2. Fill the cooling system.
3. Start the engine and check for leaks.
1helpful
2answers
Mitsubishi l200 2.5 DiD 2007 74000 miles, bubbling in header tank, over heating and pushing water back to the header tank, heater is still blowing hot air!! So dont think its the thermostat, am I more...
There are other things to test before we have the engine spread all over the yard. Cooling fan operation. Yes the thermostat hot air in heater just means hot water. start with a cold engine then start and run at a high idle if heats quickly upper radiator hose hot lower cold good but reverse no flow. remove and test thermostat (not replace) put on stove boil water and watch it open once center piece is moving check with thermometer it should agree with stamp number on thermostat. if good check for slipping fan belt. check for air restrictions on radiator and water flow.
I have replaced the knock sensor, water pump,intake manifold, thermostat, timing belts in my 1992 toyota forerunner v6. its not showing that it's overheating but the water in the radiator and overflow...
system is air locked. find the highest holes in system loosen clamp too let air esape. some systems have air valve in line some were for this. check heater for heat, no heat, no water, bleed heater core holes. you can park on hill with front of engine up. keep in mind if engine is side ways put front of engine on high side of hill. check to see if fan is working good luck
1helpful
2answers
2001 Blazer Replaced heater core now water pump is squealing and seems like low circulation
my 98 Blazer I had to replace radiator water pump heatercore and hoses. Had head gasket go. Once that happens air and dexcool corrode cooling system. Do you smell antifreeze? Are you loosing antifreeze? Check oil see if its another color not clear or black but i think light brown. Have you flushed out system?
1999 Ford Taurus over heats with or without thermastate
Either the water pump not working,,or you have a clogg some where..I have seen the impellor break on the water pump..The outside pulley was turning but the inside wasnt..
It over heats we replaced the thermistate (spelled wrong)flushed the radator still over heated took thermastate back out left it out it worked good but now is over heating again
CHECK WATER PUMP WEEP HOLE SEE IF ITS LEAKING ANTIFREEZE IF SO WATER PUMP SHAFT BEARING GOING BAD CAUSING WATER PUMP LOCK UP HARD TO TURN.MAKE SURE DRIVE BELT NOT SLIPPING DUE TO BAD BELT TENSIONER.CHECK TO SEE IF COOLING FANS TURN ON WITH AIR CONDITIONER ON HIGH.IF NOT CHECK HEATER + AC IGNITION FUSE.IF FUSE GOOD.YOU HAVE FAULTY COOLANT TEMPERATURE SENSOR.IF ALL LOOKS GOOD.CHECK ENGINE OIL IF LOOKS LIKE MILK SHAKE YOU HAVE LEAKING HEAD GASKET.IF OIL LOOKS GOOD.YOUR ENGINE CYLINDER BLOCK WATER CORES CLOGGED UP WITH RUST RESTRICTING COOLANT FLOW THROUGH THE ENGINE BLOCK TO REMOVE HEAT AWAY FROM THE ENGINE.BLOCK PROBABLY NEED FLUSHED OUT AT RADIATOR SHOP.
3answers
Car overheats and coolant boils
sounds like the thermostat may be sticking closed. i would check to see if the thermostat is opening or not
Coolant leak from upper radiator hose where it meets engine
thermistate housing is the place you refer to it fuction is to hold a thermastate to open and close water flow at 150 to 190 degree according to car spectif the thermaste sticks it causes overheating and can blow the thermastate gasget, the tole cost is about 30$ at most for the thermastate and gasget...now many other things can cause a car to over heat and cause a hose leak and somtimes it is simple to just tighten the hiose clamp at the thrmastate and problem sovled see a water leak causes the radiator to lose presure and thus with out a sealed tight water cooling system the boiling point of water is lower and thus the car over heats when in doubt stop by the local gas station and have a tech take a quick look as it could be simple as the hose clamp difficult as a therm,astate but do not let it go to warp a head gasket as this blown headgasket is what is the end results of running a car to hot
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
