The lid lock system was designed to really lock the lid during a 'spin mode operation to avoid accidents..pushing the on/off power botton usually releases the lock I can imagine that the lock/release solenoidis now 'jammed and it is best to replace it..you will have to open the top part of your washing machine to do that..2 visible screws on the sides and 2 hidden screws behind the rear portion of the top cover..be careful with this repair job electricity can kill people..good luck
SOURCE: lid closing will not allow machine to operate.
check the lid hinge on the LH side. the screws will come loose and then will not always engage the lid switch.
tighten the screws and if you need to you can reach under the top where the hinge is and bend it backwards to get it to engage the switch. usually the screws will take care of it.
SOURCE: Washer wont run unless i forcefully push the lid when closed
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
It is a simple and relatively inexpensive fix.
SOURCE: my Sharp ES-A50S washing machine won't spin dry.
my sharp es-a50s now power problem i check mean board fuse damages...i try to replace the fuse....but not work or no power ..............what other part posible damage.????????????.................
