Electronics - Others Logo
Posted on Dec 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cannot format my usb flash drive, it is a transcend jetflash v33 1gb, whenever i plug it on my pc and format it, it always says unable to complete the format, i really dont know what to do, please help me.
Anonymous
Level 2:
  • Expert 134 Answers
  • Posted on Dec 27, 2010
Anonymous
Expert
Level 2:
Answers
134
Questions
0
Helped
20796
Points
524
Hi choieeyy32
  • First a fall check whether your PC should be active in Security or not..
  • first insert your USB and scan for virus
  • if it finished then give the format option
  • some virus problem is there in your system, else in your pen drive ,so please check it
  • if 2 things are okay means definetly it will format your pen drive...
Format gb pendrive transcend
Plug it into your computer, open Windows explorer and then right click on the relevant drive, select "Format" and follow the instructions. If it still won't format, you need to remember that flash memory has a finite life. It is all about the number of "Writes" to the memory. and sometimes stuff fails. Bad connection or just a static shock to the chips will kill a flash drive.
Transcend 8GB mobile Memory card when iam not formatting in my windom 7 pc it replies Windows can unable to format
at the command prompt type chkdsk X: /f /r where X is memory card.If it doesn't work download the recovery tool here http://freeware-fix.blogspot.com/2013/04/usb-drive-is-unreadable.html
I have 2 .0 GB pendrive same is not formatted
If the flash drive can not be formatted, there are two possible
1. Damage to partition table
2. Damage to firmware
To fix the Transcend flash drive, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, repair damaged partition table and damaged firmware.
JetFlash Online Recovery, you can download here Transcend Customer Support.
How to use JetFlash Online Recovery, and analyze damage to flash drive, can you read in my blog. To find my blog, how:
Write a keyword in Google seach engine "Aplus Computer Fix Transcend Flash Drive". Analysis and how to use the JetFlash Online Recovery can you read in my blog.
Hopefully this information helps.
2helpful
2answers
Transcend 8GB JetFlash V30 Pendrive Device shows Used Space and Free space 0 bytes.
There are two possible
4gb sony pen drive do not format
Flash drive can not be formatted, there are two possible
To fix Transcend flash drive, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, repair damaged partition table and damaged firmware.
2answers
Suddenly usb pen drive stopped recognising
Try using 'JetFlash Online Recovery' .
It is advanced new software specifically developed for Transcend's JetFlash USB flash drives. It repairs your flash drives immediately through simple and user friendly interface. With such effective, safe and reliable solution, it can save your precious time and money bringing your product for traditional RMA service. Wherever you travel, Transcend JetFlash Online Recovery services you 24/7 on the internet.
* Hardware Requirements : USB port (supports USB2.0),Internet connection
* System Requirements : Windows® XP SP2/ 2000 SP4 (Administrator rights required).
Step by Step Instructions
1. Please insert your JetFlash into a PC with internet connection.
2. Run OnLineRecovery.exe and press "START."
3. A confirmation message will be displayed. If you are sure you want to format the JetFlash, press "START." If you do not want to format your JetFlash at this time, please press "EXIT" to quit.
4. The process may take several minutes. Please be patient.
5. When the format is complete, please press "Exit," then unplug the JetFlash and plug it back in to your computer.
voila, its done.
Don't forget to say THANKS
I cant able to format my transcend 2 gb micro sd memory card,when i am formatting through my nokia mobile it replied UNABLE TO FOMAT,when i format through my card reader via pc it replied WINDOWS CAN...
format it with a PC that has a fully updated antivirus this some times is a problem when a virus source code is not allowing the system to access the important part of the card for formating!
reply and rate!
I have 8GB pendrive of transcend. when ever i want to format it, screen shows that window is unable to format it. i have window XP SP2
format it by dos
start>
all programs>
run>
type cmd
format it by
format g:(you type in ms -dos)
if you drive is f then
type
format f:
37helpful
6answers
Transcend jet flash v30 32gb pen drive can not be formatted.
first of all transcend do not do a 32gb in V30 - so if its green then its fake - i suggest you try this link it tells you about the fake transcend 32gb - it tells you how to test with h2testw & also you can report the fake from who ever you bought - im hoping you bought via payapl so you can get your money back
http://fakeflashnews.wordpress.com/2009/03/08/transcend-32gb-counterfeit-usb-flash-drive-found-on-ebay-latest-brand-name-to-impacted-jetflash-v30/#comment-92
Top Transcend Electronics - Others Experts
NOEL
NOEL
Larry
August Brown
August Brown
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
