Question about Apple iTunes
Apple Application Support was not found. Apple Application Support is required to run iTunes. Please uninstall iTunes, then install iTunes again. Error 2 ===================================== This is the error I get after I load iTunes I have Vista Home Premium 32, I'm running an HP laptop I've uninstalled and reinstalled over and over and it never works. . . I need Help Now!!!!!
Posted by carvinrob on
keikii
How did you uninstall itunes? If you run into an error, or your computer while your itunes was installing, it could leave things behind messing up all the other installations as well. What you need to do is first of all make sure you don't have any instances of itunes open, or trying to be opened. Then you can go ahead and run the uninstaller on itunes.
Then you will need to go into explorer (windows+e, or right click on your My Computer icon and press "explore" from the menu), navigate to C:\Program Files\ and delete the itunes folder completely. If you get an error saying something to the effect of "This file/folder is being used by another program, please stop that program and try again." go ahead and restart your computer, and try to delete the folder again when your computer comes back up.
Then try and reinstall it, making sure that you are downloading the correct version of itunes for your operating system.
Posted on May 16, 2011
  • Julia K
    Julia K Feb 26, 2014
    I was so excited after reading your advice and tried it. My computer is still doing the same thing and won't let me install itunes. :( Mine has Windows 7 and I downloaded the correct form. This makes me sad.
Can't open my iTunes when open get error messages ""Apple application support was not found." Apple application support is required to run iTunes.
I think you have not follow the basic rule. first check your system configuration with iTunes application requirement.
If possible update your system. Now you can download a Apple Application Support file and if not helpful then read this tutorial if you have some technical knowledge https://discussions.apple.com/docs/DOC-6562#qtmoviewin
and follow Mac Technical Support for more guidance.
Jul 30, 2014 | Apple iTunes
Apple Application Support can be downloaded at this link Apple Application Support 3 0
Feb 26, 2014 | Apple iTunes
Error 7 windows error 126
Uninstall Apple Application Support, Apple Mobile Device Support, Apple Software Update, Bonjour, iTunes, and Quicktime. Basically any Apple software.
Download and re-install itunes, it will install all of the above.
Open iTunes. It now runs correctly.
I was having the same problem until I did this, and it fixed the problem right away.
Sit back and enjoy music.
May 14, 2013 | Apple iTunes
I tried to download the latest version of itunes but for someone it wouldnt download and now my old itunes doesnt work either. When I click on itunes to open it up, a message box pops up reading...
It sounds like the download removed the existing software.
I would open control panel, then click add or remove programs, then click on itunes. see if there is a repair option with the installer. sometimes there is, but if not, then uninstall it, but keep your saved files.
Then re-install it, and when it sets up, it should still accept your old saved files. That way you don't have to recopy you music, games or videos
The 'error 2" is saying that when you clicked on the icon, there was no file remaining in your system that matched what the program was that was assigned to that icon.
You can find out what the program was, and its location by right clicking on the icon, and then click on properties.
Jan 24, 2011 | Computers & Internet
HOW TO INSTALL I TUNES?
Hi rhodelinesum,
You can download and install the iTunes Application from Apple Website. Below is the link to download the iTunes Application.
http://www.apple.com/itunes/
Hope this helps.
Good Luck!
Please post back if you require further assistance.
Thanks for using FixYa.
Oct 21, 2010 | Computers & Internet
Getting apple application support error 2 have installed and uninstalled 6 times still same problem followed support suggestions on apple website no resolution. I have a compaq laptop running vista please...
1. Uninstall iTunes.
2. Download and install WinRAR.
3. Download and Right-click the iTunesSetup.exe icon and choose "Open with WinRAR".
4. Once the EXE is opened in WinRAR, double-click AppleApplicationSupport.msi and when the installer window is open choose "Repair".
Jan 12, 2010 | Apple iTunes
I am trying to download itunes onto my laptop but it wont let me download more than 76%
you sure your problem is the 'download' part?? or is it the installation part??
if it's the download part I would suggest for you to attempt to download the installation file in another computer, put it on the thumb drive and bring it over to the laptop where you want to install the itunes.
if you have problems installing itunes you probably may want to uninstall
the following programs and in the following order
  1. iTunes
  2. QuickTime
  3. Apple Software Update
  4. Apple Mobile Device Support
  5. Bonjour
  6. Apple Application Support (iTunes 9 or later)
if you can't uninstall them with 'add and remove programs', I would suggest to use this windows uninstaller and clean up utility
only once you have uninstalled all the programs above, run the itunes installer and all the programs updated will be installed one at a time.
hope this helps
Dec 26, 2009 | Apple Computers & Internet
For some reason my CD/DVD player burner on my Toshiba A135 Laptop is not recognizing CD's or DVD's. I hear the drive spinning when I first install a disk but then nothing occurs. I ran a diagnostic on...
you might have accidentally uninstalled physically...
you also might have uninstalled the driver
you might have a virus
if you physically uninstalled it... physically reseat the burner...
if you uninstalled the driver...find the driver and reinstall it...
to check for virus get dr web cure IT and do a scan...
if that doesn't work call your pc tech support they will gladly help you...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 21, 2009 | Toshiba Satellite A135-S2276 Notebook
After installing , when trying to run itunes , it says apple application support is required to run i tunes, please uninstall and imnstall again , i have done what it says. and still the same error comes...
1. Download and install WinRAR.
2. Right-click the iTunesSetup.exe icon and choose "Open with WinRAR".
3. Once the EXE is opened in WinRAR, double-click AppleApplicationSupport.msi and when the installer window is open choose "Repair".
4. Done! You can now run iTunes normally.
Crat
Oct 25, 2009 | Apple iTunes
Apple iTunes Logo
2,023 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Lee Hodgson
Lee Hodgson
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
