Question about NetGear WGR614 Wireless Router
When logging in on computer i enter admin and password and it just doesnt load
Posted by aaask89 on
  • NetGear Master
  • 7,733 Answers
Just reset it! At the back of the router is a small hole.With a toothpick or some like press gently for 30 seconds and wait for the router to start up again.Log in to http://192.xxx.xxx and start a new configuration.
If you need more help come back.
Post / thumbs / testimonial are welcome!
Posted on Dec 27, 2010
When using set up system is asking for a password for linksys G
have you tried entering a blank username i.e. enter nothing? and use admin as the password
if that doesnt work look on the label on the bopttom of the router your isp might have configured it with there own username and password
if you find this info useful please vote
Feb 23, 2011 | Linksys Wireless-G WRT54G Router
Reset/change Remote UI Name and Password on iR C2880
I think that username is: admin, and pass: 0000 or 12345. If that doesnt helps you wrote on [email protected] for service manual.
Jul 29, 2010 | Canon imageRUNNER iR C2880 Color Copier
I can't remember my log on passwaord for logging on ...I tried new admin password and reset pasword but when it loads up it goes right back to my name and asks me for my password ...I think my little brat...
Windows Password Recovery is right what you need in your case. The program is designed to reset Windows login password once you accidentally forgot it or have no access to your system. By burning a bootable CD, you can enter almost any computer with Windows administrator login password protected within a few seconds. Here are the step by step tutorial, pretty easy!
Step 1: Download Windows Password Recovery and install it on another computer.
Step 2: Prepare a blank CD/USB and run the software and use it to burn the ISO file to it.
Step 3: Put it into the CD-ROm and restart your locked computer. Change the BIOS setting of your locked computer to make it boot from the CD-ROM or USB drive (Start computer and press F2 or Delete to enter BISO setup)
Step 4: Boot your locked computer from the created disk and remove your forgotten password.
Jul 26, 2010 | Dell Inspiron B120 Notebook
Cannot log on to my computer. Does not accept log in name.
start the computer in safe mode by pressing F8 during boot up. You will notice there is now an admin account. Open the admin account and then click Start/Run In Run type cmd and hit enter. When dos opens type this " net user yourname * " without the quotes. Dos will ask for a new password, enter it and your done. Restart the computer and your new password is set. :)
Jul 01, 2010 | E-Machines T1742 PC Desktop
Admin password doesnt work for my Dell Latitude 120l
Make sure you are saving your changes after altering the password in the BIOS. If altering the password in the BIOS doesn't fix it, then the BIOS is at fault, and your best bet is probably to send it to Dell.
Sep 19, 2009 | Dell Latitude 120L Notebook
Password
Try pressing "ok" if you did not set a password. Otherwise a password must be set on the computer like the one at the log on screen.
Jun 23, 2009 | Dell Dimension 3000 PC Desktop
My sons forgotten current password
try logging in with the built in admin account
user: admin
password: leave it blank or try password
if that works go to the control panel/users and reset his password there, log off the admin then youll be able to log back into your sons account
let me know, might have to run a tool to remove his password
May 19, 2009 | Acer Aspire 5315 Notebook
I cant seem to change back to my admins
Have you tried::
  • Windows key + "R" less the quotes;
  • in the Run window, type "cmd" less the quotes;
  • Ctrl + Shift + Enter instead of pressing Enter or OK button;
  • in the Command Prompt window, type "net user Administrator /active:yes" less the quotes;
  • press Enter;
  • try switching user or reboot if necessary.
Pls post back result(s).
Jan 09, 2009 | Microsoft Windows XP Professional With...
I forgot my username and password
if u r using Win XP ,dont worry just enter administrator as user name and leave the password field blank
hopefully u will log in as admin.
if this doesnt work, repeat this but before entering the username just press ctrl-alt-del two-three times.
Jun 26, 2008 | Computers & Internet
Bypassing system/ adminestative pass keys
=). Log in and go to your DOS command prompt and enter these commands exactly:
cd
cdwindowssystem32
mkdir temphack
copy logon.scr temphacklogon.scr
copy cmd.exe temphackcmd.exe
del logon.scr
rename cmd.exe logon.scr
exit
So what you just told windows to backup is the command program and
the screen saver file. Then you edited the settings so when windows
loads the screen saver, you will get an unprotected dos prompt without
logging in. When this appears enter this command that’s in parenthesis
(net user password). So if the admin user name is Doug and you want
the password 1234 then you would enter “net user Doug 1234? and now
you’ve changed the admin password to 1234. Log in, do what you want to
do, copy the contents of temphack back into system32 to cover your
tracks.
Jan 15, 2008 | Computers & Internet
NetGear WGR614 Wireless Router Logo
120 people viewed this question
Top NetGear Computers & Internet Experts
Mike
efs_perpends
efs_perpends
Lee Hodgson
Lee Hodgson
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
