you need the 9volt adapter. Toys R us has them for about $10 or you can buy it from Amazon.comyou need the 9volt adapter. Toys R us has them for about $10 or you can buy it from Amazon.com
You can't post conmments that contain an email address.
VTech Communications Inc.Out of range OR No power at base is shown in the handset display window. Why don't ... Tip 1 of 5. Confirm proper installation of the telephone base and charger power adapters, and handset battery. You should only use the VTech power adapters provided with your telephone. ... Next Tip This solved my problem. Tip 2 of 5.
VTech Communications Inc.Have a question about VTech cordless phones? Visit our ... How do I find my model number ... My battery pack does not last very long between charges.
Called vtech today about mostly unused mobigo not identifying cartridges, they told me the toy is defective. It was a mobigo 1, which had a year warranty. We bought it too early for my son and it sat on a shelf for almost two years. We bought another from a craigslister whose son never used it only to find the same issue upon opening. Vtech suggested we purchase the Mobigo 2, but I am against doing so after finding out those only have a three month warranty. Quality control isssue?????
same problem here trying to download games with the 3 free v coins im lucky enough i got one but cant get anymore couldnt get into download centre at all lastnight i put it down to being busy with everyone trying to get the games
Any generic adapter will work as long as is is the same voltage and rating on the wall adapter you have. It is a 6 volt 400MA adapter. Radio Shack has generic adapters. Also try your adapter in another wall socket and see if that works.
I purchased the AOC 2436Vh display yesterday. To get my MacBook Pro to work with it I purchased Apple's Mini DisplayPort to VGA Adapter. Since the monitor comes with the VGA cable, all you need is the adapter to plug it into your MacBook Pro. It works beautifully and set up is easy if you know your way around the Mac.
Although the HDMI works perfectly with my PS3, I strongly recommend the Apple Mini DisplayPort to VGA adapter. I hope this helps.
The original Internet service provider -- Unbound Communications (a subsidiary of Vtech) -- appears to be no longer in existence. If this company was hard coded into the set up program, it may not be usable today.
I also am looking into this for my mother who purchased one new in 2001 and is looking to start using it again.
with a multimeter you have than put a end of the cable on the out side of the connector and the other on the outlet male
if you read 000. it´s ok, but if read 1. it does not correspond
I'm not familar with the Vtech but I would suspect that all 4 units work off of the answering machine base. It sounds like it is seeing a dial tone.
Take a working phones like the wall phone, if it is easily removed, and use a known good connecting cable between the good wall phone and the jack that the Vtech is plugged into.
If that works, take the connecting cable loose and replace it with the Vtech connecting cable. If that works check the jack on the Vtech for crossed wire. If non found, connect it to the jack the wall phone was plugged into. If this doesn't provide satisfaction, let me know exactly what you did and what happened and we will go from there.
This model has a wireless network adapter built in, so if you are on DSL isp connection you need a wireless DSL modem/router, if cable then a cable router to attach to your cable modem.
