Question about Lenovo ThinkPad X200 Notebook
Hi i have updated the blue tooth driver on my x200 and after running that i have restart the laptop manually for some reason. When it come on i have a blue screen and it said STOP:c000021a (fatal system error) The windows Logon Process system process terminated unexpectedly with status of 0x0000139(0x00000000 0x00000000) The system has been shut down
Posted by zoran Vidovski on
NOEL
    Top Expert:
  • Lenovo Master
  • 8,546 Answers
Sounds like the driver you updated is causing it to shut down.try and start in safe mode and see if you can sort it from there.
Posted on Oct 08, 2017
5 Related Answers
Anonymous
  • 36 Answers
SOURCE: Regarding Memory Parity check
this error is usually associated with bad memory cards......how much amount of memory are you using.....try reseating the memory cards(ram)....if you still get the error msg....try starting the system with jst 1 memory (if thr are 2 memory cards installd) & thn swap it with the other one......
Posted on Jul 18, 2008
Thomas F. Schneider
  • 2715 Answers
SOURCE: Windows xp will not load
Sorry but your hard drive went bad.
Posted on Jan 13, 2009
Anonymous
  • 13 Answers
SOURCE: lenvo blue screen error message when computer starts up
Please try to unplug the laptop from power and remove the battery for over 10 seconds. Then start it up again. There are other things we can try if this does not work.
Posted on Mar 19, 2009
Anonymous
  • 253 Answers
SOURCE: Blue Screen in docking station
Try going into your BIOS and setting the hard drive from your Docking Station as the primary boot device (1st on the list), then your laptop hard drive
Posted on Jun 24, 2009
Anonymous
  • 166 Answers
SOURCE: Toshiba - Satellite A75-S1253
you have to reload the operating system.get our xp or what ever os your running and boot off the cd.if you have any questions or need help with reloading the os,and data recovery please email me at [email protected]
Posted on Jul 31, 2009
Unable to install blue tooth driver for windows 7 in my lenovo 3000 G430 series laptop.as i try to install the driver it gives me error saying no blue tooth device was detected.
Restart the laptop and check the bios. Make sure that Bluetooth is enabled.
For Fn-F5 to power on and off the wireless connections on a ThinkPad, you need the Lenovo Power Management Driver installed.
Just a couple of things to check.
Sep 25, 2013 | Lenovo 3000 Computers & Internet
My bluetooth on acer aspire 4736Z was working before thanafter i am unable to access bluetooth and detect any of device i
Have you tried restarting the computer? if you already did try running windows updates see if there any updates for your blue tooth and if theres none check the manufacturer web site they might have a new driver that might fix your problem just by installing it
Feb 28, 2011 | Lifetime Acer Aspire 4736 Replacement...
Hi,I m using windows7 on macbook 3,1, but my webcam & blue tooth not found in system. there is apple builtin cam, i try to download the drivers but cant.help me plz
You should just need to insert your OSX disk maybe snow leopard, then install bootcamp drivers from it also run apple software update, from the start menu or programs. install the latest free updates and you should be good to go.
kev
Feb 21, 2011 | Apple 13.3 MacBook Intel Core 2 Duo...
I have to activate bluetooth in my fujitsu note book how can i acctivate.........
The Fujitsu AMLO Pro, by default doesnot have a blue tooth adapter . If you have ordered the blue-tooth card in the laptop when you ordered then you can switch it on using the wireless key button on the laptop. However if you have not ordered a blue tooth card with the laptop. You can purchase an external USB blue-tooth adapter.
The user manual for you laptop is on the link below for reference
User manual
Thanks for using Fixya
Proton
Oct 01, 2010 | Fujitsu AMILO Pro V1000 Notebook
Hi, My x200 notebook lips closed cannot restart. Do you know why? I had already put it hibernate and after the lip closed I tried to press [Fn][F4], the notesbook are still not starting. So I need...
Remove from the power & Take the battery OUT, wait 5 mins. Now reinstall battery, power up to wall, Now hold your finger on the Power Button until it comes on. IF you get an error message about a "Restore point" simple ignore and continue. That should get you going. if it doesn't go after this then you may have a fault on the laptop.
http://www.devicemanuals.com/guide/Service%20and%20Repair/Dell/Dell-Latitude-X200-Notebook-Service-Manual-==TXpFd05UZ3c=.html
Above, and below, is your service manual. Use this to troubleshoot your laptop.
http://laptoprepairmanual.blogspot.com/2009/01/dell-latitude-x200-service-manual.html
Jul 30, 2010 | Computers & Internet
I need a blue tooth driver for my dell laptop model 1564
Hi
You can download the Bluetooth drivers for your dell laptop from this link---
Dell laptop model 1564 Bluetooth Drivers
Download the drivers, after download finishes install them and then restart your laptop to finish the installations.
Daniel Scott
Jun 26, 2010 | Dell Inspiron i15648634OBK 1564 Laptop...
I've been using windows 7 on my lenovo T61 thinkpad the suddenly the bluetooth stopped working- it couldn't discover bluetooth devices or be discovered by other bluetooth deviced. i even tried formatting...
Your blue tooth card looks like not functioning, You can double check, plug an USB external blue tooth dongle. If it works, defenitely internal Blue tooth card is gone
Jan 18, 2010 | Lenovo ThinkPad T61 Notebook
When I install Blue tooth driver it works fine but the moment I restart the system the driver says device not found. I am using lenovo N100 with XP
please reinstall blutooth
and enable bootooth on start up by following steps
start>run type "msconfig"
select startup tab
put tick mark on blutooth apply
ok
restart
Oct 29, 2009 | Computers & Internet
How to activate blue tooth in acer 240 travel mate lap top
update your driver installer all the mother board of the laptop, if the windows is windows vista download the installer from www.acer.com to get new drivers for blue tooth.
If windows xp is using as well download from acer.com.good luck
Aug 31, 2009 | Acer TravelMate 240 Notebook
Driver installation .. Lenovo X200
I downloaded a program called drivermax and it seems to have a lot of drivers for vista and xp. the program will scan your computer hardware and then give you a list of available drivers or you could do a microsoft update they also have updated drivers for download
Mar 25, 2009 | Lenovo ThinkPad X200 Notebook
Lenovo ThinkPad X200 Notebook Logo
245 people viewed this question
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
