Yes, you may have two problems. The seals around the door are defective or the drain to the pan below the refrigerator is blocked or both. I will need you to read a few things that may help you and I am here to help you get this solved. Now because the water is inside the fresh food compartment I believe the drain is blocked in sid the back and rear of the refrigerator. Look at the first link below and see if this applies to you. Then read the second link and ask me questions if you need. Please rate me and Thank You, Sea Breeze
It sounds like the defrost heater is burned out. Remove the inside back cover in the freezer to see if the coils are frozen up. If so, more than likely your defrost heater has bit the dust. It is located at the bottom of the inside coil of the freezer.
Also, you could be have a clogged condensor coil. It is located on the out side back of the Fridge. You need to remove the panel from the lower part of the fridge and do a thorugh cleaning.
