The fan motor runs regardless of the igniter as it is also the fuel pump. Possibly you may need to replace the motor but try this first. Remove the top section of the heater this exposes the fan motor, try spinning the motor by hand,it should spin freely if it does not try some light oil in the front and rear bearings of the motor and turn it by hand until it frees up. You may need to do this several times!! Now that it is spinning free put the heater back together and try it out. If it does not work a new motor is in your future. Hope this works out for you.
Here are a couple of tips that I
wrote that tell you how to troubleshoot a Torpedo or Reddy
heater...
Reddy
Heater - Troubleshooting Torpedo Heaters
Torpedo
Heater Pump Pressure Adjustment
heatman101
heater...
Reddy
Torpedo
heatman101
