Question about Whirlpool Washing Machines
Merry Christmas! Our washing machine whirlpool
Merry Christmas! Our washing machine whirlpool 7100 series agitator will not work at all? Once it is filled with water it makes a humming noise like it is trying to agitate but nothing happens, any suggestions please?
Michael Thomas
  • Whirlpool Master
  • 3,056 Answers
Hello there and merry christmas to you too
ok please read this solution fully this will be posted in 2 posts so i can get it all for you ok
There are a couple of different reasons that this problem happnes on these machines i have this listed below please feel free to leave me a comment on any of these if you need help trying to figure out how to inspect them or test them ok but you will need a multimeter to do most of the testing.
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) i will continue in the next post
Posted on Dec 26, 2010
  • Michael Thomas
    Michael Thomas Dec 26, 2010
    Clutch
    If
    your washer was made by GE®, it may use a clutch for agitating the
    clothes. As the clutch wears out, it may prevent the washer from
    agitating well or at all. If the clutch is worn, you need to replace it.
    For this job, you probably want to hire a qualified appliance repair
    technician.
    Drive motor
    Many
    washer brands use a reversing motor. For agitation the motor runs in
    one direction, for spinning and draining, the other. It's possible for a
    motor to burn out in one direction and continue to operate in the
    other. If this happens, you need to replace the entire motor.
    Drive pulleys
    The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
    Transmission
    The transmission could have either of these problems:
    Older
    washers produced by Whirlpool® have a transmission with an
    electro-mechanical shifter. If the shifter becomes even partially
    defective, the unit may not agitate properly or at all.
    The transmission may have a worn or broken gear, or some other internal problem.
    If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
    Agitator
    The
    inside of the agitator--where the transmission shaft attaches--can
    become worn, and strip out the spline that allows the agitator to
    properly grip the shaft. Then the transmission shaft rotates back and
    forth as it should, but the agitator doesn't move properly. If this
    happens, you may need to replace the agitator and/or the transmission
    spline.
My Whirlpool duet dryer says control locked and won’t work
I have a new type of washer that locks up on me time to time I un hook it from the outlet for half a minute or so and hook it back up and it unlocks hope this helps Merry Christmas you might also try YouTube sometimes a person has had the same problem and they may have an easy fix
Dec 19, 2017 | Whirlpool Washing Machines
How do I remove the agitator from a Whirlpool washing machine ?
check this link part 5 and 7 http://www.applianceblog.com/mainforums/threads/35890-Kenmore-80-Series-Washer-agitator-loose-and-sounds-like-gears-not-quite-catching
Sep 17, 2014 | Whirlpool Washing Machines
Washing machine only washes and does not rinse or spin
in order for the washer to spin it must first pump all the water out in these cases we look further at the water dispenser pump check to make sure there are no blocks in the pipe and that the water pump is working
merry christmas
please take time to rank this advice below
thank you
Jan 03, 2011 | Whirlpool Washing Machines
It says on my Whirlpool washer panel: " Control Locked". How do I unlock it? I can't find my manual right now. Thanks
click/push the end of cycle button until the control locked indicate turns off
merry christmas
please take the time to rank this advice below
thank you
Dec 25, 2010 | Whirlpool Washing Machines
The washer will fill but will not agitate hums as if the motor is stuck or the timer will not move and popps the breaker.
the fault is called epejerking the cause im sorry to say is lost polarity and crossed magnetic feild in the capstan motor this will cost a small fortune to repair and we would write the unit off
sorry
merry christmas
please rank this advice
Dec 23, 2010 | Whirlpool Washing Machines
I have a thin-twin stacked, with a slow drip in washer, when washer is off.
the water inlet valve is worn out and will need to be replaced.
merry christmas
Dec 22, 2010 | Whirlpool WTW6700TW Top Load Stacked...
My washing machine shakes and turns sideways during a cycle. What's wrong with it? It is level.
one of the balance struts are damaged have a look at all the struts find the one that looks damaged and replace it.
merry christmas
Dec 22, 2010 | Whirlpool Washing Machines
Whilrpool imerial series washer making strange noise
The agitaor coupling or drive mechanism is stripped. You will have to pull the agitator up out of the machine to find which of the parts need to be replace. Most likely th agitator coupling.
Jan 27, 2010 | Washing Machines
Washing Machines Logo
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Michael Thomas
Michael Thomas
