Question about Jakks Pacific Spy Kit
My son got a Spynet Video Watch for Christmas. He has been charging it for over 5 hours and it still doesn't show a full charge. It only shows half a charge and when he takes it off and tries to use it the watch only works for a few minutes and shuts off. Is there anything we can do to fix this?
Posted by pdschanz on
Jean DeLauche
  • JAKKS Pacific Master
  • 2,911 Answers
Hello, Pdschanz -
Since the watch was a Christmas gift, it is probably still under warranty.
I hope you found and downloaded the instructions for the watch, saved them in a Documents file with a file name you can find again easily, printed the instructions, and read them thoroughly all the way.
If you have not yet contacted Customer Service for the watch, I suggest you do that after reading through the instructions and the FAQs near the end of the instructions.
This is the telephone number for Customer Service for Jakks Pacific Inc., manufacturer of the watch:
877-875-2557
Malibu, California
Call weekdays during normal office hours, Pacific Time zone.
This is the email address for Jakks Pacific Customer Service:
[email protected]
Source of information:
Instructions for Spynet Video Watch with Night Vision
http://www.spynethq.com/core/pdfs/instructions/Video_Watch_with_Night_Vision.pdf
Best wishes.
Posted on Jan 21, 2018
2 Related Answers
Anonymous
SOURCE: Spynet Video Watch not working - battery was
OMG!!! I am so upset right now my son's watch was on the computer charging and now all it has across the screen is spynet ....I HAVE RESET IT AND IT GOES BACK TO THE SAME THING!! I AM RETURNING IT TODAY!!! WHAT A DISAPPOINMENT
Posted on Dec 26, 2010
Anonymous
SOURCE: New Spynet Video Watch will
The external battery pack supplied in the box with the watch works in "Try Me Mode". There is a reset button on the back of the watch. Reset the unit and the USB port will work. I have two units that had exactly the same problem. Both are charging now!
Posted on Dec 27, 2010
What other chargers for Spynet watch that work?
All you need is a mini-USB to USB cable. Then use your laptop or any open USB port to charge.
Feb 05, 2018 | Jakks Pacific Spy Kit
My spynet video watch won't charge.
If you have a Iphone charger base unplug the wire then just cilp in the long retangular part of the usb charger (also works with a nitendo charger) then plug itno the wall connected to the watch. not everyone needs a computer used to charge it!
Sep 24, 2013 | spynet Spy Net Video Watch
AFTER HALF HOUR MY BATTRIES ON MY MOBILITY SCOOTER SHOW GREEN
Could be - I would take the scooter or battery to a car store and they will load check the battery - That is, they will cause the battery to do work, and measure the voltage.
Measuring volts while the battery is at rest will indicate full voltage. That would be a flawed test.
Dec 30, 2012 | Health & Beauty
Nikon Coolpix L110 camera was bought for me for Christmas 2010. Worked fine at first, but now seems to be having problems. Batteries don't last. I just bought new batteries in Feb/March this year...
You have to charge the batteries for nearly 8-10 hours. Brand new batteries also require a full recharge of 8-10 hours.Not only making sure the batteries are charged, have you changed the battery in the menu under type of batteries.
Download this manual :
http://www.nikonusa.com/pdf/manuals/noprint/L110_ENnoprint.pdf and go to page #114
Buy EN-MH2-B4/MH-73 Kit (4 Rechargeable Batteries + Charger)
Jun 14, 2011 | Nikon Coolpix L110 Digital Camera
My son's spynet watch has stopped working. Have tried to charge it using different usb, but not even registering as plugged in on the computer. Anyone else had this problem? Think will have to return it,...
Hi there we had to take back his first spynet watch because the speaker decided not to work then we took back a second spynet watch because it would work when it felt like it...our son really liked it too, however after the second watch we didn't wan't to keep having problems so he decided to buy something else...gave up trying to get on their website because it kept freezing and couldn't download spy missions so we had nothing but problems with it ...hope that helps
Dec 30, 2010 | JAKKS Pacific SpyNet Snake Cam
I bought our son a Spynet Video watch for Christmas and we charged it but when we removed it from the charger, it turned off and wouldn't turn on. I then thought maybe we needed to download some kind of...
A bit late to the party, but two things come to mind. If the watch is new old stock with a few years on it, more than likely the battery is bad, it won't charge any more. Also, the power supply may be bad, I use 5 volt one amp charger, also, the manual says to charge it with the screen on, I tried that, and the battery will never be fully charged because the screen being on drains the battery faster than the charger can charge it.If the watch is working but the battery is low, connect the charge cable to the watch, then to the charger, otherwise the charger will pull the battery down too. So, let the screen go blank, then charge it, I have tried this method multiple times, and every time, assuming the battery is good, it fully charges in few hours. If you are adventurous, you can upgrade the battery to 450mah, it's a little bigger than the one it comes with, but lasts a lot longer, only a small amount of modification to the plastic strips made into the watch back need to be done, simply remove the strip closest to the electronics and it will fit just fine.
Nov 21, 2017 | Jakks Pacific Spy Kit
Spynet Video Watch not working - battery was removed fine but will not charge properly and have to change time and date everytime plugged in USB slot again to charge. Is this just a piece of **** I should...
Dec 26, 2010 | Toys
Cannot tell when sansa mp3 player is fully charged.
Make sure the hold switch is not engaged - it will interfere with the charging process. Here is a link to the full user's manual:
http://www.sandisk.com/sansa/assets/English/products/Clip/Clip_userguide_en.pdf
-Tha Mp3 Doctor
Dec 28, 2008 | SanDisk Sansa e260 MP3 Player
Casio GW-1200BA G-Shock
Try taping it to the inside of your window for a couple days and see if that makes it charge up enough to act right. You might also want to make sure that you don't have the "auto light" on. If the light turns on when you tilt the watch to a 45 degree angle then press the light button for 2 seconds to shut that off. If that doesn't work for you then you are probably going to have to have the battery changed.
Dec 31, 2006 | Casio G-Shock GW1200BA-1AV Wrist Watch
Jakks Pacific Spy Kit Logo
156 people viewed this question
Top JAKKS Pacific Toys Experts
ray gallant
Scott Bright
Level 1 Expert
Tom Chichester
Are you a JAKKS Pacific Toy Expert? Answer questions, earn points and help others
