Make sure that the sound output connectors (the red and white ones) are correctly plugged in (the colours corresponding at both ends of the 3-headed cable) and that the sound volume in the ATT box is almost to the max.
Look at the input or video select button. Change it once and attempt to change channels, if the problem persists continue to change the input selection until you can select channels.
THANK YOU AND PLEASE RETURN FOR ADDITIONAL HELP IF NEED BE.
Hi jjreid
Look for a pc audio input at the back of your tv/monitor(there`s usually one).
And you will need the cable with 2 mini phones 1/8"plug at the ends(that is one on each end)
Otherwise you will have to use separate speakers
Hope this help Good luck
you can use any vga monitor with the same color output and resolution setting just goto craigs list in your town and look for someone throwing one out detach old cable and reapply to your screen by either soder or splicing the wires independently together this is tricky
Pin
Name
Function
RED
Red video
GREEN
Green video
BLUE
Blue video
n/c
not connected
5
GND
Signal ground
6
RED_RTN
Red ground
7
GREEN_RTN
Green ground
8
BLUE_RTN
Blue ground
9
VDC
5 VDC supply (fused)
10
GND
Signal ground
11
n/c
not connected
12
SDA
DDC / I2C data
13
HSYNC
Horizontal sync
14
VSYNC
Vertical sync
15
SLC
DDC / I2C clock
That means that there are solid state components on a printed circuit board that are soldered into place. If the set is a 13 inch it would not be feasable to drop any cash into it as there are 13 inch combo TV sets going for as little as 59 bucks. Good Luck
