Question about Danby DWC440 Wine Cooler
Unit has been operating in a wine closet and just stopped working it there anything I should check or clean? [email protected]
Posted by swaney167 on
corkyd1946
    New Friend:
    Problem Solver:
  • 14 Answers
Does the 'closet' have any ventilation? if not the unit could have overheated and shut down or , worse, burned up the motor. any 'electric smell to it? under the unit, should be a fan, it that stopped it will not cool. look for lint build up under the unit or around any air vents. How old is the wine cooler? can you get any info from the Wine cooler's mfg web site? www.danby.com/products/wine__beverages -
Posted on Dec 26, 2010
My dual zone wine cooler stopped cooling. Power is good and fan is working.
Fan is wired separately from the cooling unit. you may have a wire corrosion issue. take put the shelves, disassemble the back of the unit from the inside and observe the wiring to see if there are broken or corroded wires/connections. R/R if necessary.
Dec 14, 2014 | Magic Chef Dual Zone Wine and Beverage...
Vinoview #272 02 35 18 wine cooler stopped working and makes a clicking sound
sounds like you have a compressor overheating is it enough air circulation where the unit is located and check to see that the condensing coil and motor are clean too.
Dec 11, 2013 | Wine Enthusiast VinoView Silent 35 Bottle...
HOW TO STOP DUST BUILDUP IN AC CLOSET
Seal closet with caulk or mastic or foam.including top, sides, platform and around base of unit. If base is not sealed it can pull from outside of closet through door. If base is sealed but top and sides of closet are not then return air can pull from inside closet from attic or inside walls. Either will turn your door casing into a filter.
Aug 31, 2012 | Ruud Heating & Cooling
Ruud UBHA-17J10NFDA
Are you serious? You have your A/C in a closet? What were you thinking? You're lucky you're still alive. There is soooo many things wrong with this, I don't know where to begin.
GET IT OUT OF THE CLOSET, and put it in a window where it belongs. Clean your closet, Then go to the doctors and have your respritory system checked to make sure you're ok.
Hope this helps.
Randy.
Aug 31, 2012 | Heating & Cooling
Unplugged the wine cooler to move for painting. When we re-plugged it in it was not working at all. Took off the back and cleaned out any dust from the fan. All of the wires look like they are in place....
First check your breakers. Sometimes re plugging an item can cause a surge and pop the breaker. Maybe some paint might have gotten in the outlet and preventing a clean contact. If all fails, try plugging in the unit in another outlet to see if the problem lies within the outlet or the wine cooler.
Mar 21, 2011 | Cuisinart CWC-1200 Wine Cooler
Noisy when running
condenser fan blades are cover with lint or the fan motor may be going out. Clean fan blade first before doing anything else. If noise stops after cleaning the fan blades; hooray! If not you might have to replace the fan motor itself. Test and re-check before taking other step(s)
Jan 04, 2011 | Haier BC112G Wine Cooler
Ice is forming on the outlet holes on the face of my 4200 xlt
you should check to see if the fan at the back of the unit is operating, and you also need to check for dust build up, if the fan is working then clean and defrost the unit, try it again, make sure there is nothing blocking the airflow, if the motor is not running, replace the motor, hope that helps
Jan 18, 2009 | Vinotheque Whisperkool 4200 Wine Cooling...
Vinotemp VT-16TEDS has light on but doesn't cool
First check the grating over the fan in the back. If it is covered with dust, there won't be enough air flow and the unit won't cool. Clean the dust off and see if it cools back down. It may take a long time to cool down if it is full of wine, so I recommend taking the wine out to test if it works.
Jan 17, 2009 | VinoTemp VT24-G 24 Bottle Wine Cooler
U-Line 15WC Wine Cooler Problem
Cheak The Compressor relay is fault
May 20, 2008 | U-Line 75WC Wine Cooler
Danby DWC440 Wine Cooler Logo
306 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Marvin
Marvin
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
