Archos 70 Internet Tablet Logo
Posted on Dec 26, 2010
Apps lib was not working properly it keeps saying check conection i have formatted the device then updated to the newest opperating software i have re downloaded apps lib and it says its installed but it wont open and kepps giving me white screen then after a few mins says connection error check connection but the conection seems fine pls help
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 27, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2586
Points
Same here, come on archos at least post an aknowledgement on appslib! Day 4 of owning the device, don't let me down after choosing *you*.
Archos 101 user
  • 2 more comments
  • msstiles Dec 27, 2010
    Same issue!
    Sounds like we will be returning the device
  • Anonymous Dec 29, 2010
    I'm having the same issue, however, I was not having this issue until after Christmas Day. If you go to the Archos website you can't even contact them via the Customer Service tab. I think the sheer volume of new users may have crashed their system, but unfortunately they aren't sharing that with anyone. Very disappointing as everything else about the tablet is great!
    Hey All, I just went to www.appslib.com on my tablet and reinstalled the AppsLib from the site. It's working now. Give it a shot.
  • Friendly PC Repair
    Friendly PC Repair Dec 30, 2010
    I talked to Coby USA about this concern today. They are aware of the issue and are working on a fix. They said so many were sold for xmas that the appslib server crashed because so many people were trying to download apps. This started on Dec 25th, but worked fine up to that date. They said it could be a couple of days before it is fixed and to keep trying the appslib. There isnt a problem with the tablet................
Anonymous
Level 1:
New Friend:
  • Posted on Dec 29, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2586
Points
Uninstall the AppsLib, then go to www.appslib.com and reinstall the application. You will have to sign up for an account and then your AppsLib will be working again.
Anonymous
Level 1:
  • Posted on Jan 06, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2586
Points
I had the same problem. Just go to appslib.com/latest on your tablet and a new apk file will download. Install this update and every thing should be fine
My Nokia 301 is saying operation failed every time I try to listen to a song
Here are some steps you can try to resolve this issue:
Update your phone's software: Make sure your Nokia 301 is running the latest software version. You can check for updates by going to Menu > Settings > Phone > Device Updates .
Reset your phone: A hard reset may help resolve the issue. Before doing so, make sure to back up all your data as this will erase all data on your phone. To perform a hard reset, go to Menu > Settings > Restore Factory Settings .
Check the file format of the music files: Ensure that the music files you transferred from your smartphone are in a compatible format such as MP3, AAC, or WMA .
Try a different music player app: If the above steps do not work, try using a different music player app such as VLC or Winamp .
Neoniq NQT-73GiQA. Why does it keep indicating 'Google play services has stopped'?
This is probably the most common error faced by Android users. This error is not critical and will not harm your android, it can be very annoying when the messages pop-ups continuously and says, "Unfortunately, Google Play Services has stopped working". So if your facing that error, and are unable to troubleshoot the problem, Here are your answers to the fix, and resolve your issue. So let's get started with all fixes to solve the error.
Reasons
Almost every kind of Playstore error occurs due to the Network issue, or any hardware or software issue. The main reason is Play Store is hard-wired with a specific device, and it may happen that accidentally Google has rolled out a wrong version of Google Play store in your device.
Before You Start
Before proceeding with the fixes, let's have a look at some short-tips that can help you in coming out from the issue as well, If any of the below-mentioned things happened with your device, so firstly perform these short-tricks. In most of the cases these short tricks solve the problem
  • If the app is crashing so frequently.
  • If the app isn't opening.
  • If the app doesn't respond.
  • If the app isn't working properly.
Try these small tricks, to fix the issues
  • Refresh networks.
  • Reboot your device.
  • Check application is updated.
  • Check for the Software or Android update.
  • In this case of Google Play Services, try uninstalling the updates.
Samsung gt b7722
Go to Settings > App Settings and delete the apps. and fresh install them. Also you should check if your device is up to date on softwares. you might need an Operating system updates. Check for the same in settings and software updates hope this helps.
Aug 27, 2013 • Cell Phones
1helpful
I just received the tablet for christmas. I cannot get the appslib to work. I downloaded from the appslib website. and i have microsd chip in the tablet. When I click on appslib from the home screen it...
suzanneb77,
I don't know about getting apps, but the Apps Lib is specifically designed to work only with certain Archos devices; perhaps that's your issue.
1helpful
HI I think my Step son has formated his NW E002 through windows. It dose not seam to have ANY run files on the device and displays "NO DATA" when the play button is pressed. Has anyone gor a working one...
I fixed the thing myself by checking the formating via windows explorer (It should be FAW or RAW not FAW32)
Then downloading the updated version of sonicstage from sony.
this player needs this to acept music and the version on the disk will NOT work properly with windows 7 (another joy of a new Opperating System)
Quite handy as I can now have him keep his noise off windows media player. by directing sonicstage to use a seperate library.
Mp3 player will not connect to windows vista on device manager it says ''This device cannot start. (Code 10)''
code 10 = this device is either not present,is not working properly,or does not have all the drivers installed(it may also be a manufacturer specific code)
Make sure it is connected properly,if that doesn't work try updateing the driver from the driver tab.
(this is verbatim from Team LiB)
2helpful
Connect to PC and use device manager to repair
If you have a Philips HDD Series, it will not work with Windows Vista or Windows Media Player 11 except for briefly, then the player will stop working one day. Your only hope is to use it with Windows XP and Windows Media Player 10 - it is, basically, an obsolete player at this point in time.
The Philips Device Manager has a strange feature - it only properly updates your device if you have the newest version of the Device Manager:
Download the newest version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Update" tab
-Tha Mp3 Doctor
Printer keeps saying usb not conected
Can you print from it? It sounds like you just need to install the software that came with it, it has all the drivers you need or go to hp website and download the newest drivers. Update your drivers and then it will recognize it.
Top Archos Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Archos Computer and Internet Expert? Answer questions, earn points and help others
