Question about Acer Computers & Internet
My acer aspire 1670 cannot be turned on immediately after it is shut down. It takes about 30 minutes before it can be turned on again.
Posted by vdannyansah on
Fred George
    New Friend:
  • 91 Answers
This may be due to heat issue ot it may be a ACPI driver issue
go to device manager and uninstall the ACPI power button under system devices as well as the ACPI driver under computer
reboot the system and reinstall the chipset driver and reboot the system
Posted on Dec 26, 2010
Recover user account password on acer aspire 1670
is it a BIOS password that you have forgotten if so go to this website http://www.biosremoval.com/acer_aspire_1670_bios_password.html it will tell you a step to step on how to clear the password so you can get on without using a password.
Jul 30, 2012 | Acer Aspire 1670
My Acer Aspire 9805WKHi wont turn on past the main acer start-up screen after my battery died. I didn't realize it wasn't plugged into the ac adapter so it was running only on battery.
Try taking out the battery and just plug in the ac adapter and see if it powers on that way. If it does use it that way for about 30 minutes then shut down. Put the battery back in, and keep it plugged in and wait about 30 minutes before you turn it on. This should refresh the battery enough to start charging.
Aug 24, 2010 | Acer Aspire 9805WKHi Notebook
About 10 seconds after i turn on my aspire 3690 the fan shuts down. the laptop will run for several minutes and then it shuts down also probibly from overheating. The fan starts each time i start but shuts...
First thing I'd check is for a BIOS update for your computer under the Acer support pages (acer.com). In some cases, thermal control updates are included in newer version of the BIOS, if it is a manufacturing problem.
Goto http://www.cpuid.com/hwmonitor.php and download Hardware Monitor, start the computer and immediately run the hardware monitor app to check how high the temperature on the CPU gets before it shuts down.
Continuing use under this condition may damage your Windows installation because of the sudden shutdown.
Mar 21, 2010 | Acer Aspire 3690-2196 Notebook
My aspire 5920 will shut off after a few minutes or after 30 minutes, it does boot back up and then sometimes it will shut down again. Does not do it all the time. Help me
Its overheating, clean the fan out.
Also, make sure your bios is up to date and that your power settings are not set to shut down after a certain amount of time.
Thanks
Oct 01, 2009 | Acer Aspire 5920-6727 Notebook
Acer laptop goes off after 30 minutes exactly. wont come if i try immediately but after about 5 mins comes on when I power it. help
you have set ur computer to sleep or hibernate after 30 minutes of inactivity. you can customize this in you power setting.
Control Panel-> Power Options
Sep 27, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
My Acer Aspire One 150 shuts down automatically after about 30 seconds to one minutes. nothing seems to be helping.
You didn't say what you have tried, but if you go into the control panel, select > Power Options, ithen n the left side panel > "Choose when to turn off the dispaly." Adjust the setting according to using the battery or plugged in. You can also pick "Change when the computer sleeps" and make adjusments there.
Another thing you can be aware of is the life of the battery. If it is low, it will shut down also.
Sep 12, 2009 | Acer Aspire One AOA150-1126 Notebook
Pc keeps shutting down
hi
do you have the power saving settings to switch laptop off after a certain lenghth of time?is the laptop overheating?are you using it on a soft surface eg deep pile carpet?
Jan 24, 2009 | Acer Aspire 3690-2196 Notebook
Laptop auto shuts off - will not come back on
have you checked the power coming fine. If you were working on battery mode it cud be coz of battery issue...
remove the battery & switch on the laptop in power mode.
Dec 03, 2008 | Acer Aspire 5050 Notebook
My Acer Lappy turns off automatically!
This could be a heat issue. Make sure that nothing ( eg dust) is blocking the air vents.
Jan 11, 2008 | Acer Aspire 5630 Notebook
Computers & Internet Logo
99 people viewed this question
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
Michael Thomas
Michael Thomas
