Question about Apex Digital PF2720 27" TV
What is the difference between CC1, CC2, CC3, etc in the closed caption options in the menu? I would like to move the closed caption to the bottom of the screen, if you could help me with that too that would be great!
Posted by coffeeduane on
Anonymous
    New Friend:
For different languages I think cc1 is English. The rest have never worked for other languages for me.
Posted on Oct 24, 2011
Can I turn the caption mode off with the remote?
CC (Closed Caption)
To select the options in the CC sub-menu, press the MENU button or the #
button. A new menu will be displayed showing the following CC settings:
CC
The CC feature is available when watching regular analog (NTSC) TV.
Select from CC1, CC2, CC3 or CC4. Closed Caption for regular TV is
usually CC1 or CC2.
Digital CC Style
The Digital CC Style feature is available when watching digital TV.
Select either As Broadcaster or Custom. If Custom is selected then
you can customize the way Closed Caption is displayed.
1helpful
2answers
Closed caption is on the screen and i can't remove it.
On your TV Remote:
CAPTION Cycles through the Closed Caption:
?? Anlalog Closed Caption:CC1/CC2/
CC3/CC4/TT1/TT2/TT3/TT4/Off
?? Digital Closed Caption:Service1/
Service2/Service3/Service4/Service5/
Service6/Off
3helpful
I haven't been able to put closed captioning on tv. I don't understand how and what code to use to get the closed captioning to work.
Enable Caption Using the Original Remote
  1. Press the [CCD] button to change the CCD mode.
  2. Using this button will set the Closed Caption mode when viewing a DTV or TV channel.
Enable Caption Using the TV Menu
  1. Open the Menu screen, select the third icon, in the middle, this is the Setup Menu.
  2. In the Setup Menu, choose the Caption option.
  3. Caption: There are three items in it - Analog Closed Caption, Digital Closed Caption and Digital Caption Style
  • Analog Closed Caption: CC1, CC2, CC3, CC4, TEXT1,TEXT2, TEXT3, TEXT4.
  • Digital Closed Caption: Service1, Service2, Service3, Service4, Service5, Service6.
  • Digital Caption Style: There are two Caption Styles. One is the automatic function set as the broadcaster, while the other is the custom style where you can adjust the font size, color, opacity, background color etc., accordingly.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
1helpful
How do you remove the subtitles?
Subtitles are controlled by 'CC". Closed Captioning. Look for a CC button on the remote or captioning.
Captioning usually is in the menu as well under 'settings'.
Closed captioning has several settings. OFF turns all captioning off. CC1, CC2, CC3 & CC4 are captioning styles. Text is for text channels.
I can't get the closed captioning to go off. please help. i have the remote, but it is not an option from the menu.
U have a CC button on the remote.Use that CC button turn all CC1,CC2,CC3 off.U will have no more captioning.Or go to the menu turn all caption CC off and all TXT off too.
Closed caption
CC (Closed Caption)
Press the down button to highlight the CC (Closed Caption) selection.
Press the > button. A separate menu will appear with the following CC
settings
CC
When watching regular analog (NTSC) TV, the CC feature is available in the
Setup menu.
Press the down button to highlight the CC selection.
Press the > button to select CC1, CC2, CC3 or CC4.
Once the adjustments are completed press the LAST button repeatedly to exit
the OSD completely.
Closed Caption for regular TV is usually CC1 or CC2.
Subtitle
Analog:
1. go to setup menu
2. press the DOWN menu button to highlight the analog cc section
3. press the right button to select off/cc1/cc2/cc3/cc4 (keep in mind closed caption for reg tv is usually cc1 or cc2)
digital:
1. Go to that handy setup menu again
2. Press the down button to highlight the digital cc selection
3. press the right button to select OFF or SERVICE 1 thru SERVICE 6 (any of these should work)
Closed caption
Go thru menu pages one at a time until you find CC / Text...
Selections might be CC1 , CC2 , CC3 , Text 1 , etc. You may
have to try each CC for your signal source......T.
More details = more help !
Apex Digital PF2720 27" TV Logo
Top Apex Digital Televison & Video Experts
Ekse
 Francisco Mauricio...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
