Question about Jakks Pacific Spy Kit
New Spynet Video Watch will not charge. Will only turn on with charger attached.
Posted by pete45901 on
Anonymous
    New Friend:
The external battery pack supplied in the box with the watch works in "Try Me Mode". There is a reset button on the back of the watch. Reset the unit and the USB port will work. I have two units that had exactly the same problem. Both are charging now!
Posted on Dec 27, 2010
  • 3 more comments
  • aastorga01 Dec 29, 2010
    THANK YOU!!!
  • wyndre21 Dec 29, 2010
    Odhran from Ireland was very disappointed that we couldn't get the watch to charge but then we read your advice and he is very excited that he can still use it!
    Thank you!!!!
  • AtTheHub Dec 29, 2010
    My watch would charge, but would not turn on when not connected to the computer. Resetting didn't solve the issue. After calling the Jakks Pacific customer service line, I received these instructions:
    There is a slot in the plastic on the back of the unit just below the prongs for the 'Try Me' battery pack. There is a plastic tab inside the slot. Use tweezers to gently pull out the tab.
    This finally solved the problem!
  • bmopal Dec 31, 2010
    Thank You! I don't think I would have ever gotten this thing to work without your post. I am really disappointed at how poor the directions were to get this toy up and running. I spent way too much time on this. Hopefully my son will be good to go now. Thanks again for your help.
  • kmontrose321 Jan 03, 2011
    OMG - That was the most stupid thing I have ever heard of before from a "toy". Thanks for the help from you guys or I never would have found it. I of course have now destroyed the back of the watch because I also pulled out the white plastic piece that was in the hole for the 2 prongs. Anyone know if I have completely messed things up?
Anonymous
I got my to work on my Mac running lion by plugging in the temp battery that came with the unit. Then reset the watch (tiny button in the rear of the unit, you will need a pin or paper clip to depress the button) I left the temp battery installed and then plugged it into the USB. Finally, it charged and then I removed the temp battery. Good luck. The manufactures really need to fix these bugs. I wasted way too much time on this on xmas morning. I will NOT recommend this toy.
Posted on Dec 25, 2012
sharquille
    New Friend:
Are you it will work
Posted on May 22, 2013
What other chargers for Spynet watch that work?
All you need is a mini-USB to USB cable. Then use your laptop or any open USB port to charge.
Feb 05, 2018 | Jakks Pacific Spy Kit
My spynet video watch won't charge.
If you have a Iphone charger base unplug the wire then just cilp in the long retangular part of the usb charger (also works with a nitendo charger) then plug itno the wall connected to the watch. not everyone needs a computer used to charge it!
Sep 24, 2013 | spynet Spy Net Video Watch
I lost the charger for my spynet,how to get a new one
Almost all smart phones use the same charger as the spynet, so check there first before you go out and buy one.
All you need is a 4pin mini-usb cord. Go to any electronics store and tell an associate and they'll be able to help you find exactly what you need. Bring the watch in with you for good measure. All in all it will probably cost about 10-12 bucks depending on where you go.
Good Luck,
Rodrick
Apr 22, 2011 | Video Game Consoles & Games
I bought our son a Spynet Video watch for Christmas and we charged it but when we removed it from the charger, it turned off and wouldn't turn on. I then thought maybe we needed to download some kind of...
A bit late to the party, but two things come to mind. If the watch is new old stock with a few years on it, more than likely the battery is bad, it won't charge any more. Also, the power supply may be bad, I use 5 volt one amp charger, also, the manual says to charge it with the screen on, I tried that, and the battery will never be fully charged because the screen being on drains the battery faster than the charger can charge it.If the watch is working but the battery is low, connect the charge cable to the watch, then to the charger, otherwise the charger will pull the battery down too. So, let the screen go blank, then charge it, I have tried this method multiple times, and every time, assuming the battery is good, it fully charges in few hours. If you are adventurous, you can upgrade the battery to 450mah, it's a little bigger than the one it comes with, but lasts a lot longer, only a small amount of modification to the plastic strips made into the watch back need to be done, simply remove the strip closest to the electronics and it will fit just fine.
Nov 21, 2017 | Jakks Pacific Spy Kit
Lost spynet video watch charger - help !
my sons friend lost his too. i used my moms phillips mp3 player charger and it worked. i dont know if this will hurt the battery or not, you can always go to jakkspacific.com and try to contact the maker (jakks) to see if they offer replacements.
Dec 26, 2010 | Video Game Consoles & Games
Spynet Video Watch not working - battery was removed fine but will not charge properly and have to change time and date everytime plugged in USB slot again to charge. Is this just a piece of **** I should...
OMG!!! I am so upset right now my son's watch was on the computer charging and now all it has across the screen is spynet ....I HAVE RESET IT AND IT GOES BACK TO THE SAME THING!! I AM RETURNING IT TODAY!!! WHAT A DISAPPOINMENT
Dec 26, 2010 | Toys
Jakks Pacific Spy Kit Logo
4,702 people viewed this question
Top JAKKS Pacific Toys Experts
ray gallant
Scott Bright
Level 1 Expert
Tom Chichester
Are you a JAKKS Pacific Toy Expert? Answer questions, earn points and help others
