Probably too late for you, but others may benefit as I just did this.
In your trunk on each rear side panel, you will find several rubber stoppers approximately 1" wide. take a flat head screwdriver and pry underneath to loosen then pull the stopper out.
Take a socket set you and find the right size socket for your nut and take out the 2 nuts on top and the bolt at the bottom (my bottom bolt didn't have a stopper on it).
Pull out the tail light assembly. Remove the bad bulb from the back of the assembly and replace with a new bulb (look up type of bulb to buy in your owners manual). Replace hardware and test lights.
