Question about Oster 0.7 Cu. Ft. Compact Microwave
Our Oster microwave operates normally, but it doesnt heat the food at all. ?
Posted by marc_pacific on
A Miller
  • Oster Master
  • 8,404 Answers
Please remove the cabinet and check the door safety interlock switches. Micro switches near the door latch assembly are #1 to failure because we open the door to check whats cooking while the machine is running. The tiny contacts arc and eventually burn. Then they are not able to tell the oven the door is closed, the magnetron is not turned on ... no magnetron ... no heat. Get replacemente at electronics parts store near you or from a FixYa.com advertiser.
Thanks for visiting FixYa.com
Posted on Dec 26, 2010
How do I get the heat to work?
Hi Marc, there is no 'heat' per say with microwave ovens as one would find in a convection oven. Microwave ovens operate by generating electromagnetic fields (within the microwave band) that causes water molecules in the food item to vibrate/rotate creating friction/heat - within the food item as opposed to the surrounding space (this would be convection)
Oct 26, 2014 | Oster Microwave Ovens
Oster microwave OM1101NOE wont heat carosel turns light is on time runs but not heat
There are three things to consider, the magnetron "heats food" high voltage diode "sometimes cracks" and the high voltage capacitor "sometimes shorts" one or more can cause the symptom of no heat. I recommend a professional to assess.
Mar 08, 2012 | Oster Microwave Ovens
My Oster microwave (model #OGG21401) doesn't heat. When operating the light will turn on and the carousel will turn but food will not get hot. Can you provide a solution to my problem? Thank you.
Check the door safety interlock switches for proper operation. #1 trouble with microwaves that operate in all respects but no heat.
Thanks for your question @ FixYa.com
Sep 16, 2011 | Oster 0.7 Cu. Ft. Compact Microwave
Ihave model ofg41101 and it just stop heating up food
It is likely the magnetron is defective, "heats food" the cost to repair will approach a new microwave oven.
May 07, 2011 | Oster Microwave Ovens
The microwave is not heating up at all. food comes out still cold
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Nov 12, 2010 | Oster OGB61101 Microwave Oven
Everything appears to work. but the food does not heat up
The lack of heat would mean a failure in the magnetron circuit. It is the part that generates microwaves that heats the food. If it is making a loud buzzing noise when you operate the oven, it usually means that the magnetron has failed. It can cost as much as a new oven to repair, so it not worth fixing.
Oct 05, 2010 | Oster Microwave Ovens
Maytag microwave oven model mmv4205bab not heating food
maytag microwave model # mmv4184aaq operates normally but will not heat food or water
Mar 07, 2010 | Maytag MMV4205 Microwave Oven
Oster 0.7 Cu. Ft. Compact Microwave Logo
283 people viewed this question
Top Oster Microwave Ovens Experts
Lawrence Oravetz
NOEL
NOEL
ChinthakaJ
ChinthakaJ
Are you an Oster Microwave Oven Expert? Answer questions, earn points and help others
