Question about RCA S1000 MP3 Player
My RCA S1010A series won't unlock. The "lock" button is in unlock position
Posted by fel_don on
2 Related Answers
Anonymous
SOURCE: cant turn on my mp3 player
holding the player with the circular button on top, press and hold the triangular button on the bottom left of the circle.
Posted on Jun 20, 2008
Andrej.cet
  • 338 Answers
SOURCE: I have an RCA S1010A player and it won't turn on.
keep it, though it may be broke.
If your your PC still recognizes it,
you still have en external harddisk, like a thumb-drive.
Perhaps the manual is of help:
http://support.rcaaudiovideo.com/Downloads.ashx?prodid=105&mediaid=654&force=true&file=products/S1000/media/S1000_UMEN.pdf
Sorry I could not do more for you
Posted on Jul 25, 2009
1helpful
How do you turn off the FPA lock on the RCA TRUFLAT TV? I Can't access menu.
Hello
First of all, you must ahve its original remote control to unlock FPA lock. If you have it, go through the folloing steps.
* Hold down Menu button on the remote control, and the Volume Down button on the at the same time for at least 4 seconds. "The set won't say so, but the lock will be released".
** Hold down Zero button on the remote control, and the Volume Down button on the TV. The set won't say so, but the lock will be released.
*** Hold down Menu button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. The set won't say so, but the lock will be released.
The FDA is lock and the TV wont stay on
Hello
The lock of RCA TV can be unlocked. You must have its original remote control to do this. If you haven't one, buy a new one or just borrow it from any of your friends or relatives who own the same model RCA TV you have. To unlock it, try these methods. One amoung them will surely unlock your TV.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
When I plug my Polaroid 1835 in to download my pictures three things happen. 1) this "card protected" sign pops up and 2) the delete "X" button isn't working 3) When I try to rotate...
Take the memory card out of your camera and look at it. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
4helpful
I accidentaly turned the FPA lock on my TruFlat RCA tv and the original remote broke. i just bought a RCA universal remote from best buy. now how do i get rid of the lock?
Hello
It will be very difficult to unlock RCA TVs without its orginal remote control handset. Anyway just try this, This is the actual proceedings to unlock the RCA TV with its original remote. If you fail to do this with your present universal remote control, just buy an new original one from RCA Authorised Service Center at tyour town, or just borrow it from any of your friends or relatives; just to unlock your set. After unlock, you can use the universal remote control. Just follow the proceedings given below. One amoung them must unlock your RCA TV.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
1helpful
I changed the key batteries for my 1999 BMW 323i after they died. Afterwards the remote unlock and lock won't work, the car also won't start but it can turn over/on and the radio and the lights...
stick the key in the ignition, turn it to the on position, remove it within 5 seconds, then hold the unlock button down and press the lock button 3 times within 10 seconds and release both buttons. The doors should lock/unlock to give you confirmation and your key should work.
I need to reset my password on my rca HD52W55
Hello
If your RCA tv has locked or you want to reset your password you can opt any one of the followinf option to unlock it without any passcode nd can reset it after.
2answers
I was trying to look for the input, and accidently locked the screen
You will need to have the remote:
Press the VOL+ on the remote control and the CH+ button on the front of the TV.
The TV will prompt you to enter a new password.
2helpful
Cant turn on my mp3 player
RCA S1000 MP3 Player Logo
Top RCA Audio Players & Recorders Experts
Jean Sintulaire
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
