I have a Integra receiver model number DTR 66 and I have no sound. it appears to have everything connected and should be working. I would like to know how to reset the receiver or what steps do I need to take to try and repreoduce sound...?
Posted by asmoke3 on
David Dunn
    Brigadier General:
  • 8,546 Answers
NO sound at all? That would be odd as its internal FM receiver is independent of any user connections. I'd work on getting FM to work first, then move on to more complex issues.
The manual is here:
http://www.retrevo.com/support/Integra-DTR-6.6-Receivers-manual/id/550ag000/t/2/
To reset the AV receiver to its factory defaults, turn it on and, while holding down the [Video 1] button, press the [Standby/On] button. "Clear" will appear on the display and the AV receiver will enter Standby mode.
Posted on Dec 26, 2010
My integra av receiver model no DTR-70.1 amplifier displays but no sound what could be the problem?
http://www.integrahometheater.com/faqs.php Check the connections and try a master reset?
Perform a master reset. To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode.
Jul 03, 2018 | Integra Audio Players & Recorders
"handshake" between DTR 5.9 and an LG Blu-ray player
You will have a defective processor pcb. You may want to see if you can get Integra to give you a one time repair on this.
Mar 26, 2014 | Integra Onkyo Rc-711m Dtr-4.9 / 5.9...
No sound
Sounds like an input button has been changed. Check that out first
Jan 11, 2014 | Integra DTR-7.1 Receiver
Integra DTR-5.6, no sound for am/fm tuner
reset receiver if that does not work You will have a defective processor pcb
Aug 24, 2013 | Integra DTR 5.6 Multi Media Amp
My left rear speaker has no sound. All others work. I have tested the speaker on a different reciever and it works fine. My reciever is a integra DTR 5.5
Swap your left and right rear speaker over. If you still get no sound from the right speaker connected to the left speaker connection on the receiver, then you have a fault on the receiver output. Check your manual first to see if any setting switch off the rear speaker before taking the unit for repair or replace
Nov 26, 2009 | Integra Audio Players & Recorders
Doing a job for a friend. Reconnecting all his gear to an Integra DTR-7.1. Everything works except for the surround. I can't get the rears to speak from the receiver. I have verified they work (wires...
if you have everything connected properly, then it wont necessarily utilize ALL of the speakers, unless you have a true 7.1 signal coming in. is it using optical or coaxial? make sure that the options on the receiver are set right......the rears on 5.1 and 7.1 dont work unless they are told to by the receiver....and the signal coming in from the external source ( dvd player, ps2, ps3, xbox....) tell the receiver what it is going to need, in order to utilize the full signal. everything is labeled, and it sounds like you know what you're doing, when it comes to hooking this up, which is always good. it sounds to me, like something isnt configured properly, so i would start there. it may take a while, but you get the idea.....
Sep 24, 2009 | Integra DTR-7.1 Receiver
Low to no volume output from Integra DTR-5.2 receiver
most higher end integra's have a input level adjusment or input selection for each and every input. Perhaps you are not on the correct input, go to onscreen programming and check out the input level and input select - also try the tape in another input like tape 2 or cd. It will not hurt the receiver for a test. Also, if you are using the cheap cables from the manufacturer - try a pair of cables that you know work or go by some. BTW, you don't need to spend $40 for cables order them online through amazon or other store. Gold / sliver plated oxygen free are best.
Jun 30, 2009 | Integra DTR-5.2 Receiver
No output to subwoofer per-amp
you may have to go into the onscreen menu and enable it,that shuld work
May 11, 2009 | Integra DTR-8.3 Receiver
No sound from speakers from components with Integra 6.9 receiver
Turns out it had to do with one of the settings for the new Blu-Ray player.
Thanks anyway.
Jan 17, 2009 | Integra DTR-9.1 7.1 Channels Receiver
538 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
