Question about Horizon T91 Treadmill
Screen states Lube Belt , do not have user Manual , Where are lubrication points and what type "lube" can I use ?
Posted by frankl9784 on
Electro Med Services
  • Horizon Master
  • 6,694 Answers
It is necessary to lubricate your treadmill running deck every six months or 150 miles to maintain optimal performance. Once the treadmill reaches 150 miles, the console will display the message "LUBE" or "LUBE BELT". The treadmill will not operate while the message is showing. Hold Stop for 5 seconds to suspend message for 5 miles. Your treadmill came with a bottle of lubricant which can be used for two applications. If you need lubricant, contact Horizon Fitness. Only use lubricant provided by Horizon Fitness.
• Turn off the treadmill with the on/off switch, then unplug the power
cord at the wall outlet.
• Loosen both the rear roller bolts. (For best results, place two removable
marks on both sides of the frame and note roller position). Once the
belt is loosened, take the bottle of lubricant and apply it to the entire
top surface of the running deck. Tighten both rear roller bolts
(matching up the marks for proper position) to original position. After
you have applied lubricant, plug in the power cord, insert the safety
key, start the treadmill and walk on the belt for two minutes to spread
the lubricant.
• Lubricate the air shocks with Teflon based spray.
• Once lubrication is complete, reset the console by pressing and holding 'STOP' and Speed '+' buttons for 5 seconds.
ok
Posted on Dec 26, 2010
BurtWizeman
  • 4 Answers
Holding the stop button for 5 seconds does not get rid of the message. Also holding the Stop and Increase Speed button do not reset. All buttons give a beep when pressed with the exception of the stop button.
Posted on Nov 21, 2014
  • BurtWizeman Nov 22, 2014
    Making New question from this.
The clutch is difficult to remove, it was not lubricated when built. Is there a way of getting the clutch off when it is dry?
You talking about a manual clutch? Pry the pressure plate off after the bolts are removed. The guide pins rust. Do not use lube to reinstall it. Any type of lube on the flywheel, clutch, or pressure plate will cause premature failure. The only lube is for the throw out bearing to the transmission shaft. and some on the pivot point of the throw out arm.
Apr 27, 2016 | Cars & Trucks
Horizon manual
once lubrication is complete, reset the console by pressing and holding STOP and SPEED + buttons for 5
seconds
Aug 02, 2014 | Precor Treadmill Belt/Deck/Lube Kit,...
Healthstream GS1165T treadmill, where do I have to lubricate it, i have lost the manual
see the video and proceed according. lube the rollers bearing front+back +drive belt motor test , and replace the belt if necessary.\\God bles you
Jul 05, 2013 | Exercise & Fitness
Rear Roller need lubrication.
see the video attached and proceed according, this is a matter very easy to lube the rollers bearing. Use the extension plastic coming the LUBE and put a little oil for lube the rollers bearint. Use WD-40 NOt use for LUBE deck belt, this 100% LUBE SILICONE special.
God bless you
Nov 26, 2012 | Exercise & Fitness
Appeared on the screen of the device that need oil, but does not have a place to fill the place of oil????
The only place to oil is under the walk belt. You dont need to worry about it. If you want to, you can order a kit from iconservice.com.
Hope this helps, Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Dec 05, 2010 | Reebok Vista Treadmill - RBTL13305
Belt is slipping and squeaking when walked upon what type of lubricant should be used
Sounds like the motor belt is slipping. Make sure the belt from the motor to front roller pulley is tight.Once you have that adjusted lube and adjust the walk belt. The squeaking is usually from the motor belt. Many treadmills(Proform, Nordictrack for example) use Silicone lube (lube n walk, or silicone With teflon from Lowes works good) Call the manufacturer to make sure it uses a silicone lube.
Nov 23, 2010 | Cadence Exercise & Fitness
Are there front-end grease joints that need lube periodically or are they sealed and don't require fresh grease?
There are places to lubricate the joints and such in the front end. The ball joints certainly have lube points if nothing else does. Anything that could be metal to metal contact needs periodic lubrication. Check your owners manual for Lubrication types. Most are using a molediumdysulfide based lubricant in the newer vehicles. It is easily available at Walmart and most auto parts stores. Just don't use a graphite based Lube unless it is specifically called for. If your owners manual is short on information on this you should pick up a Haynes repair manual on your vehicle. It will specify lube points and intervals and what type of lubrication to use.
Jul 24, 2010 | 2004 Toyota Sequoia
Lubricating a treadmill
The only lube required is between the walking belt and the deck. You can get the lube from iconfitness.com. Lift the walking belt and squirt some on the deck from each side, underneath the belt in the area where you usually walk. Walk on it for a few minutes to spread the lube around.
Mar 04, 2010 | Cadence Weslo 825 Treadmill Walking Belt
It is saying schedule maintance see owners manual
The manual should point out specifics but this is usually a message that is generated by the miles on the mill. Most important maintenance on a treadmill is keeping belt lubed. We also vac under the hood( motor area) to get out dust, lent and debris. and lube elevation mech. Check owners manual for type of belt lubricant.
Nov 16, 2009 | Startrac Fitness Products Lamar L1400...
Horizon T91 Treadmill Logo
1,951 people viewed this question
Top Horizon Exercise & Fitness Experts
gbob59
Vernon Taylor
john h
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
