Question about Lexmark X7170 All-In-One InkJet Printer
My printer keeps saying 'the printer is paused"..
Posted by cherrill312 on
5 Related Answers
mdgm
  • 89 Answers
SOURCE: Printer keeps pausing itself!!
By UI do you mean RUI (Remote User Interface)? Have you installed a network kit? If so did you upgrade firmware using SST? If not, you need to do this or printing won't work.
In service mode. Copier > Display > Version > PS/PCL there needs to be a number e.g. 30.06. If there is no number the copier does not have any print drivers on it and won't be able to print. You also need to have a N BOOT-ROM (included in network kit). There Should be a N next to the number for BOOT-ROM under Copier > Display > Version if a N BOOT-ROM is installed.
Posted on Jul 17, 2009
Anonymous
  • 151 Answers
SOURCE: kodak printer 3 in1 says its paused when i try to print from pc
Basically the problem is caused by the printer spooler which is a printer system file that was installed on windows XP
For this problem kindly try doing the ff:
  • click START then select RUN
  • Type net stop spooler
  • Type net start spooler
  • Then try printing
  • if problem still persist call 1800 421 6699
Hope this will help
Thanks
Byron
Posted on Sep 01, 2009
Anonymous
  • 330 Answers
SOURCE: lq2180 when print few lines, the printer pause
its may be heaving problem with the control panel clean replace the buttons or replace the control panel and check it ................
Posted on Dec 22, 2009
Ronil Singh
  • 126 Answers
SOURCE: printer keeps saying "out of
check paper sensor in the tray, maybe its broken
Posted on Jan 08, 2011
printmastert
Lexmark
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: keeps pausing job won't print. also won't
    Your firewall could be blocking some printer communications. Make sure to allow full access to all Lexmark and printer communications in the program rules/permissions for your firewall. For more information on how to configure the settings for your firewall, visit the Lexmark website at http://bit.ly/iNwkNs.
    Posted on May 31, 2011
    Printer is paused all the time
    Hello, sounds like your drivers are messed up, reload them to the computer or the connection cable maybe bad. If neither of these fix then the printer is bad.
    Sep 05, 2012 | Canon PIXMA MX870 Wireless Office...
    My printer status says it is on pause and it won't print. How do I get it off of pause?
    I'm assuming that you're using a Mac. Try to uninstall the Lexmark driver first then download an updated driver online: http://bit.ly/McHL54
    If it doesn't work, try to reset the printing system:
    1. Open System Preferences and click "Print & Fax". Then click or right-click on the blank space around the list of printers on the left-hand side.
    You should see a pop-up menu and the option to "Reset printing system...". Once you select the option, the OS will restore the CUPS printing system back to its original default settings. NOTE: This will, of course, erase all of your print queues.
    Then add a print queue manually: http://bit.ly/SxD5Za
    Aug 08, 2012 | Lexmark 90T9105 - Pro 901 All-in-1
    Keeps saying printer is "offline", but still
    Contact the printer customer service, they may need to install an updated driver (especially if the printer is a Lexmark).
    Aug 24, 2011 | Apple MacBook Pro MB991LL/A 13.3-Inch...
    After each print the pause button will continue to blink and will not print another label. I have to manually open the print head, close it and press pause for it to print. I do not understand the...
    The ribbon is the transfer rolls same thing.
    But check if you have not activate the pause mode in your driver!
    This is an option to have the printer pause after printing
    Aug 04, 2011 | Zebra Z4M Printer
    Keeps pausing job won't print. also won't scan... "can't load application" scans only to flashdrive.
    May 14, 2011 | Lexmark X4650 InkJet Printer
    Hi, I'm not able to print on my hp 1320 printer. When I go to the print option I notice a word "paused" under the printer icon. I opened each tap on the properties and there is nothing that...
    Go to printers, right-click your HP 1320 and choose "Continue".
    The printer should change the status to ready after printing the remaining print job in memory.
    Hope i was of any help. If so, please rate me.
    Thank you.
    Pcsimples
    Mar 20, 2011 | HP LaserJet 1320n Printer
    I have downloaded the driver and it all says it's good to go, but when I hit "print" it sends it to the printer and it says "Printer ready" but the status says "stopped" and...
    make sure when you hit print and the dialog box comes up...make sure that the PRINTER is highlighted not the fax, scanner,copier or office etc...I had the same problem when I first got mine.. its a great machine also check that the printer is set as your default printer.. youll see a check and default next to the printer name in the printers folder.. and make sure your not all jammed up with pages to print open the printer folder (usuall in your startup in the bottom ri side where your start up items go.. if you have any questions email me back good luck
    PS worst u have to do is delete the entire printer/fax etc set up and run the disc again. peace out
    Feb 03, 2011 | HP J3680 Officejet All In One Printer
    Kodak printer 3 in1 says its paused when i try to print from pc
    • Then try printing
    Hope this will help
    Thanks
    Byron
    Aug 28, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
    Lexmark X7170 All-In-One InkJet Printer Logo
    215 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Muntejaya Ginting
    Muntejaya Ginting
    CheckitRight
    CheckitRight
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
