Question about Jandy Aqualink Rs4 One Touch Control System Control System
How do I delete an Aqualink RS4 program? The filter is on all the time. When I set a new program start and stop time the controller keeps adding programs versus replacing an/the existing programs.
Posted by chrisw0613 on
David Spradling
    Top Expert:
  • Jandy Master
  • 11,320 Answers
To delete a program go to system set up go to programs add or delete or edit if doing on its own disconnect spa side remote if goes away replace spa side remote if no spa side reset board clear memory and re program write down all auxs and JVAs
Posted on Jan 30, 2016
5 Related Answers
Anonymous
  • 22 Answers
SOURCE: Need to clear a program from my aqualink
Start with the cancel button. It will then prompt you to cancel the desired program. Go through the menu as you would with a program but follow the prompts to cancel. Remember, press cancel to start.
Posted on Dec 30, 2008
Anonymous
  • 22 Answers
SOURCE: I need to clear a
Start with the cancel button and follow the prompts
Posted on Jan 01, 2009
Anonymous
  • 15 Answers
SOURCE: I have an Aqualink RS4. I want to delete the 3
The best thing to do is to clear the system memory. Aqualink can have a problem with "ghosting" Things just go on by themself when not programed to. A bad spa side remote can do that to but that is another problem.
To clear the memory
Push the menu button once
Push the back arrow to "System setup"
Push star * or enter button
Push back arrow till diplay says " clear memory "
Push star or enter
Push star or enter again to comfrim.
You will get a message "earsing memeory"
Now you can reprogram system
If you want differant run times like a summer and winter timing you can do that with the program groups
Hope this helped
Keith
Posted on Jun 23, 2009
Anonymous
SOURCE: Jet blower randomly starts ...
most of the time this is caused by a faulty spa side controller. If you trace the line from the spa and disconnect it see if that solves the problem.
Posted on Aug 06, 2009
Anonymous
  • 5 Answers
SOURCE: pool lights go on randomly--not programmed to go on at all
make sure the light is pluged in a port that is for like a spare aux. any time you add programs you must hit the store button.
Posted on Oct 05, 2009
Aqualink rs4 owners manual
go to system set up then go to program highlight what you want to program then add start and stop time if to run all the time start 2:00am and stop 1:59 am it will shut off for 1 minute then restart
Jul 21, 2014 | Jandy Aqualink Rs4 One Touch Control...
Aqualinks rs4
Go to menu , program the pick pool and input your desired schedule.
Make sure the day and time is set correctly!
How do I cancel filter programs
go to system setup go to program if there is a program it will let you edit or delete
Apr 02, 2014 | Jandy Aqualink Rs4 One Touch Control...
The inside control display on my Aqualink RS4 is red instead of green on the filter pump button. What does this mean?
either the temp is below 38 degrees if so it is in freeze protect if not 38 degrees or lower bad temp sensor go to system set up and go to program go to freeze protect and un check the filter pump
Feb 16, 2013 | Jandy Aqualink Rs4 One Touch Control...
Program Group A is selected and the filter pump is programmed to start at 12 noon but does not turn on. If I start it manually, it runs fine and will turn off at the proper time. What could it be? ...
Check to see if your nine volt battery is good. The aqualink will hold it's programs but lose time and date. At that point it goes back to factory set. You have to have a fresh battery to avoid this.
Nov 30, 2010 | Jandy Aqualink Rs4 One Touch Control...
Jul 24, 2009 | Jandy Aqualink Rs4 One Touch Control...
Dec 26, 2008 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy Aqualink Rs4 One Touch Control System Control System Logo
5,200 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Steve Slater
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
