Question about Andis Improved Master Hair Trimmer
Hi; i just bought a andis improved master clipper and the blades stop working right after i tried to adjust the voltage ,i can hear the motor running, but the blades don't move, please help me! thanks!
Posted by jgconcrete on
Anonymous
    New Friend:
I just had this same problem. My andis Masters where working and they started making a loud sound and the blades stopped working. The Problem was there wasn't enough power. I used a screw driver and turn the power adjusting screw to the Right with a flat head screw driver.the sound got louder but after I keep turn it the blades started moving again and the blades got quiet again. Tada a Quick Fix.
Posted on Jan 07, 2011
Andis master clippers lose power
Oil the blades and then adjust them. You will need to add oil while grooming from time to time and then clean & oil them again when finished.
Sep 23, 2012 | Andis Improved Master Clipper/Trimmer...
I need to take apart my andis master clipper to see what part i need to order i need the manual take apart the clipper
Stop, Their no manual on how to take your Andis Master apart. The Andis Master has small parts that you can lose. The adjustment on this clipper are not easy to do. I
Feb 11, 2011 | Andis Master 01557 Hair Trimmer
How do you get the noise out of an Andis Master after using the adjustment screw on the outside.
you have to adjust the screw on the side of the clipper with the regular flat screwdriver, just turn clockwise until the clipper gets quiet
Jul 29, 2010 | Andis Improved Master Hair Trimmer
Andis trimmers are making loud noise when used outside US
First off all when buying a step down transformer for these clippers or any other electrical equitment make sure u read the label check cycle 50/60 ,and watt transformer need to be the same are close enough,with is hard to get on tha market,get it made custom,I'm a barber and we have a little trick open your andis clipper ,get spong cut it neatly just a bit thicker than the space between movin part and amateur (coil) insert spong between,not centre bit top bit to blade that's where knocking comin from it can cause that movin bit to break,trim spong until u get it quit but able to cut ,note blade will get hot because of wrong transformer and can damage coil
Nov 01, 2009 | Andis Styliner SLII Hair Trimmer
Misses hair when cutting
You probably need a new blade drive, which is easily replaced yourself, if you are so inclined.
Apr 20, 2009 | Andis 01690 Hair Trimmer
My GTO model Andis clippers blade is not properly aligning..how do I adjust it?
The problem with Andis clippers is that you are not told how to get the most effective job out of you're clippers,i can attest to that because i've repaired and adjusted hundreds of them,every user wants a crisp cut,nothing less, you want find the answer to that in the instructions,so you're encouraged to send the clipper back to Andis company,i did that once just to see if they really understand their own tool,the clipper cut no better upon it's return,it was then that i discoverer the ultimate solution,blades has to be precise,only then will you get a crisp cut,for any type of hair ,so before you get rid of blades,remember 85% of the time the problem is with the adjustment of the blade.
Dec 17, 2008 | Andis 01690 Hair Trimmer
My andis clippers are experiencing blade not moving. it is not cutting.
Push top blade to right side right with finger,then turn clipper on and dip  into 3 in one oil,blades only,let clipper run for one minute,clean excess oil off blades,if clipper still want vibrate,take blades off the clipper and clean them,then place back on clipper, I've had this problem many times,i also repair clippers,adjust blades,etc...
Oct 09, 2008 | Andis 01690 Hair Trimmer
Loud andis master clipper
adjust power screw in one quarter turn
Apr 23, 2008 | Andis 01690 Hair Trimmer
Hair Clippers not clipping
for Shorty8 adjust power screw,check connector fork,if too tight losen tension inside the clipper
Aug 28, 2007 | Andis 01690 Hair Trimmer
Andis Improved Master Hair Trimmer Logo
1,023 people viewed this question
Top Andis Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Ross Keen
Marvin
Marvin
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
