Question about Alpine CDE-102Ri CD Reciever, iPod and USB Controller Car CD/ MP3 Player
Everything i plug into the usb slot it just says UNIT ERROR. even brand new, formatted flash drive with only one mp3 on it. in the setup mode its set to cd/mp3 mode.
3 Related Answers
Anonymous
  • 129 Answers
SOURCE: Device Error on ALpin CDA-105 CD reciever
Sorry to say my friend, but the problem is with the Archose. I recently installed a Soundstream unit for a customer of mine, and he had an Archos aswell. The Archose will go in to slave mode, and act as a removeable mass media storage, but that's as far as it will go. Other mass storage units will work fine, you can even use a regular old usb thumb drive, but not the Archose.
Posted on Aug 07, 2009
Anonymous
SOURCE: My CDA-9886 usb error
I just got an A-male to A-female USB extension cable to hook up to the back of my Alpine CDA-9886 headunit and connect to my 32GB USB. All of the songs are MP3 and works with my brother's headunit. But when the USB is plugged into my headunit, it says error. How can I fix this?
Posted on Jun 07, 2011
Anonymous
  • 21 Answers
SOURCE: i have a problem on
MAKE SURE THE USB DRIVE IS FORMATTED IN FAT 32 -------- MY GUESS IS IT CANNOT READ FROM THE USB STICK
MAY NEED TO TAKE THE STICK BACK TO YOUR COMPUTER AND RIGHT CLICK ON THE DRIVE TO CHECK THIS ......... IF IT PLAYS ON THE COMPUTER TRY A REFORMAT ...
SAVE YOUR MUSIC ON PC FIRST --- THEN REFORMAT USB DRIVE CHOOSING FAT FORMAT ---- REINSTALL MUSIC ..........
Posted on Jun 29, 2011
I have a brookstone brand record player with the ability to convert records to mp3/wma files via a sd slot and a usb slot. Every time I plug in an empty flash drive/ usb toward an external hard drive, or...
External drives require to be formatted before use on somewhere else..
Pls "format" it on your Pc and than try again....
Sometimes proper formatting is possible on the equipment itself (like Digital Cameras )
I was not able to get into your units detailed specs to see if such feature is existed..
if its exist ,you must access thru "set up menu"
Secondly ,if the display recognizes the HD than your Record player will create its own Files/ folders..try to record something even it reads "no file" and than plug it into your PC to see what has been recorded..
Hope this helps!
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 24, 2011 | Audio Players & Recorders
My freestyle player says format error how to fix?? it was working fine and then this error.
Hello there,
Q.: My player is having a DRM error / Format Error / Empty Disk Error
what do I do?
A: For all 3 errors, the first step is to attempt to reset the player, this can be accomplished by pressing the play and menu
buttons down together for approximately five seconds. If reset does nothing, make sure all the songs are .mp3s, if all songs
are .mp3s, attempt to format and re-sync the player.
if you need it
How do I convert my iTunes into MP3 format?
A: See Music Conversion Instruction Document: Transferring and Playing Music on Freestyle Audio mp3 players with
iTunes.
if you need to format the player here is how for MAC and windows.
Q.: What's Reformatting, How do I format my Player?
A: Reformatting your player basically wipes you player clean and deletes all songs, leaving you with a blank slate. Like
most removable drives you can reformat your player with no worries of damage to the unit. When reformatting on a Mac
make sure you choose the MS-DOS format style.
(CAUTION: FORMATTING WILL ERASE EVERTHING ON THE DRIVE)
PC (Windows NT, 9x, XP and Vista):
1. Plug in the Mp3 Player.
2. Put the Player in removable drive mode. Under "My Computer" you should
see the player as a removable drive.
3. Right click on the "removable drive" and a Drop down menu should appear.
4. In the menu select the option "format..."
5. Make sure that "FAT" is selected as the file system and that Allocation
Unit size is set to "Default Allocation Unit Size"
6. Now click format and wait, after it says format complete, you're done.
MAC OS 9 (and Earlier):
1. Plug the player in.
2. Put the player in removable drive mode.
3. Single-click the disk's icon on your desktop to format.
4. Pull down the "Special" menu from the top of the screen and select "Erase
Disk..."
5. Enter whatever name you want in the "Name:" field in the window that pops
up. If the disk is a hard drive, select "Mac OS Extended" from the
"Format:" pull down. If the disk is not a hard drive (such as a Zip Disk
or other removable media), select "MS-DOS or MAC OS Standard" for the
format.
6. Press "Erase." The drive will be formatted and ready to use.
MAC OS X (and later):
1. Start your computer and plug in the player in the USB port after the Mac
OS has completed loading.
3. An icon for a removable drive should appear for the flash drive on the
desktop.
4. From the Dock, open "Disk Utility".
5. Click "Erase" from the top selector (next to "First Aid")
6. Choose "MS DOS File System (FAT16)"
7. Click the "Erase" button
8. Perform the instructions given on the screen and finish the formatting.
if you need any help with a Step let me know and i hope this information was helpful don't forget to Rate .
Jan 27, 2011 | Freestyle Audio MP3 Player
How to remove write protect on my usb flash drive
if nothing is on this flash drive but what you really want to delete
this is what you do
plug flash drive to pc
go to my computer
select the flash drive (make sure this is the drive)
right click and format....(this will delete everything on the flash)
May 13, 2010 | iLO (2 GB) MP3 Player
Jul 18, 2009 | Alpine iDA-X100 Car CD/ MP3 Player
16GB Flash Drive NTFS Formatting
what brand flash drive is this? some of the cruzer brand flash drives are partitioned to 2 drives. you may need to go to the manufacturers website and remove the partition with a 3rd party software. if it IS a cruzer, that software is on the larger of the two drives that show up when you insert the drive.
Jul 11, 2009 | Electronics - Others
Clarion DXZ385USB will not play from the usb input
It is not compatible. I had the same receiver and mp3 player. according to the Clarion website, an "ERROR 5" is the message for a compatibility problem. You probably got an "ERROR 2"(format problem) when you had the player plugged in and then cycled through the sources(that's how I received the error).
I have since bought an Ipod and the USB input works just fine. Clarion says the deck is MTP compatible, but it will not run a lot of MTP devices. Only Ipods and certain memory sticks. The Creative Zen Vision M is read as an MTP device when it it plugged into anything like a computer, Xbox 360, and the Clarion USB receivers. The Clarion units even attempt to read it as an MPT device, but will not play. It is not an issue with the receiver or the MP3 files. The Creative Vision M is not a compatible device, sorry.
May 29, 2009 | Clarion DXZ385USB Car CD/ MP3 Player
USB flash drive not holding data
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Dec 12, 2008 | SanDisk Sansa e250 MP3 Player
Cruzer 2gig won't see usb 2.0
1)maybe not all of the slots are USB2.0 try the furthest slot from the one you put it in or in front of your computer.
2) you should NEVER format a flash drive. It will not work after a format. You now need a new disk.
Feb 19, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
New songs= black screen
try to remove the battery, wait 30 seconds and replace it
this should reset your sansa,
a real hard reset isn't possible,
you can format it though
warning, this removes everything
To format your Sansa E200 series MP3 player:
1. Open "My Computer."
2. With the player plugged into the USB port, right-click on the player (if in MTP mode) or the drive letter for your player (if in MSC mode) and select "Format" from the right-click menu.
3. Press "Start."
4. You will receive a warning that the format process will erase all data on your device.
IMPORTANT: Make sure you have backed up all of your data from the device before continuing with the format. Procedure will erase everything off the player. Agree to the warning.
5. The format will complete. Close the format window and your player should be ready to use.
After the format, please install the latest firmware update for your player. Please visit the following link to download and upload the Firmware on your Sansa E200:
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00...
PLEASE NOTE: All files will be deleted. Backup your files. Your MP3 player must be in MSC mode before installing the Firmware update.
To set your player in MSC mode, please do the following:
1. When the player is turned on, press the “Menu” button.
2. Navigate to the “Settings” menu.
3. Navigate to “USB”.
4. Under the “USB” menu, go to “MSC”.
After changing the player to MSC mode, reconnect it to your computer. The screen on the MP3 player should read “USB Connected” and "MSC”
You can now complete the Firmware update download from SanDisk.com on your device.
Installation Instructions:
1. Unplug any other USB flash drives that's connected to any of your USB ports.
2. Download the firmware to your PC
3. Plug in your e200
4. Double-click on the downloaded firmware (e200fw01.00.12.exe) and follow instructions
5. Unplug your e200
6. Device will do it's own update process and will restart.
The device should be ready to be used again.
Dec 16, 2007 | Audio Players & Recorders
MP3 ilo
You should backup your data and format the player. Plug her in, copy your music onto your computer, then format it by right clicking the drive in My Computer, then going to Format, then clicking Start. After it's finished, copy your music back over to the player and it should be sorted.
Sep 07, 2007 | iLO MP3 Player
Alpine CDE-102Ri CD Reciever, iPod and USB Controller Car CD/ MP3 Player Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
