KitchenAid 24 in. KUDM25SH Built-in Dishwasher Logo
Question about KitchenAid 24 in. KUDM25SH Built-in Dishwasher
My KitchenAid KUDM25SH has been operating fine for 9 years, but will not drain now.
Posted by rainer_koeni on
Anonymous
  • KitchenAid Master
  • 1,902 Answers
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose or the drain pump not working. First try to clean the drain hose and drain pump filter for any clogs, then check drain pump operation. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Dec 26, 2010
Not cleaning the dshes. Material lrft on dishes. Suspect poor water flow.
Fill with salt. Clean out all rotary arms. And put a dishwasher cleaner through. The rotary arms get blocked with lime scale.
Dishes are coming out with milky film after all the cycles
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Water keeps leaking out when not in use.
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
styikuuf
Kitchenaid KUDM25SH dishwasher - water not heating
Depends on how much that you use the dishwasher. It's possible that the element is burnt out. If you know how to check the element, you can with a meter, however if you don't know electrical, then by all means get a qualified individual. There isn't a thermostat. Everything is on a timer circuit.If there is a preheat on the machine, you could set it to that and the element should come on also.
1helpful
I do not know how to turn off child lock safety feature. How do I do this?
To turn on or off the child lock
Press and hold the ENERGY SAVER DRY button for 4 seconds.
Here is a copy of the owners manual if you have any other questions.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209744037.pdf
6helpful
Child proof lock light is on, cannot run the dishwasher
To turn off the Child Lock
Press and hold ENERGY SAVER DRY for 4 seconds. The
light turns off.
Door latch will not open door
This happened to my washer. 3 months later my stupid warrenty company 1st American finially gets someone out to tell me that the whole front panel needs to be replaced, and is offering under $300 to replace it.
Open Questions:
Top KitchenAid Dishwashers Experts
Mike
Marvin
Marvin
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
