SOURCE: restart computer and monitor says not optimal display
If you are indicating you have like 5 or 10 frames stacked across the screen causing the can't see problem, here's the "what-to-do". Reboot the computer and use "F-8" to get it started in safe mode. Make the necessary corrections the the display settings. Save and reboot. That should restore so that you can see to optimize the settings once back in normal mode.
Let me know if I missed it.
SOURCE: Facebook display problem Samsung SynchMaster 713BM monitor
it must be the drivers your using for the monitor. Have you checked the pins connector are all straight. as bent pins will cause this.
http://www.howtodrivers.com/model502115.html
webpage link for drivers
AndystUK
Vote me happy
SOURCE: 17'' samsung synchmaster 794MG
hit your MONITOR lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some monitors on main board ( also on CRT circuit board ) at some soldering joints crack develops....then due to loose contact picture becomes small in size or abnormal width,etc ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......monitor main board & CRT circuit board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting monitor lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again ................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good monitor service engineer .............iam from bangalore - 09986222774 - [email protected] ( computers, laptop, printers, etc )..............
