SOURCE: Vizio L42HDTV10A sound problems
I have had my flat panel vizio L37 for under 2 years. The sound is completely gone - any suggestions? No more warranty unfortunately. HelpME
SOURCE: Vizio 42 in L42HDTV10A no power no lights no nothing
Yeah if you don't have any power at all, no lights or anything its the power supply.
SOURCE: 42" Vizio - no picture no sound
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The
internal circuits are jammed because of electrostatic
charges accumulating on capacitors, or because of a wrong voltage read
by the main chip on your monitor controller board. this started the
protection circuit.
2 The protection circuit detected a wrong
voltage or abroken contact, identified an internal fault and kicked in
, starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay
particular attention at inverter and power board, power board can be
inspected looking for bulged or leaking capacitors, then tested with a
multimeter. The inverter is more difficult to test , there is need to
read voltages, should be done by a tech. Also the LCD controller board can cause same problem
SOURCE: DTV signal will not come up on start up but after warm up
Was just the DTV card replaced only or the mainboard? Replacing the entire mainboard should do the trick.
SOURCE: No digital signal search
Check your manual to see if it has 2 tuners, digital and analog. If it doesn't have a digital tuner, you will need a converter box.
Hello, this is Matthew Gonzales with DISH Network customer service. To answer your question, yes the ViP211 will work with a dish 500. It will receive the standard channels as you asked, but if you wish to get HD, the dish on your home will need to be upgraded. Hope this helps!
