Question about Samsung SCX4623F Laser All-in-One Printer
I use Ubuntu 10.04 and I want to install my printer Samsung SCX-4623F. What do I have to do? Thank You. Eros.
Posted by Verdafolio Greenwood on
  • Marvin
    Marvin Dec 25, 2010
    What is Unbuntu 10.4, have never heard of this in the USA?
wisiny.com
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Samsung Master
  • 848 Answers
I use Ubuntu 10.04 and I want to install my printer Samsung SCX-4623F. What do I have to do? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:[email protected],we sincerely hope we can help you!
you can also check this boards whether suit you:
IP 45130A Samsung BN44 00127F Power Supply Backlight Inverter
Posted on Feb 02, 2015
Anonymous
  • 298 Answers
Hi there and welcome to fixya,
What's the model code for your printer?
There are three options;
XAX, XAA, XBG
For a direct link to the XAA type, follow the link below:
http://www.samsung.com/us/support/downloads/SCX-4623F/XAA
otherwise, you'll need to select the correct model code on the drop down.
On the Driver tab. Download the driver file under LINUX.
Hope this helps.
levbit
Posted on Dec 25, 2010
I have a samsung fax scx 4623f it keeps on indicating printing
Dear
Pl. update the firmware. else replace the main PBA.
Thanks.
Feb 26, 2015 | Samsung SCX 4623F - Multifunction fax /...
My samsung scx-4623f always "paper jam in exit area" every time i print even though i always put out the jammed paper in the exit area.
While Samsung SCX-4623f printer always "paper jam in exit area" you get paper checks or trigger sensor paper cup
cong ty bao ve support
good luck
Jul 07, 2014 | Samsung SCX4623F Laser All-in-One Printer
I use ubuntu 12.04 and i wand to install my printer samsung SCX-4521F. What do i have to do?
sir i am using ubuntu 12.04 i need to install samsung printer drivers
model num is scx-4521fs
Oct 25, 2012 | Samsung SCX 4521F All-In-One Laser Printer
Cant get pc fax to work scx-4623f. Manual faxes work fine, dial tone fine. Have tried Samsung SmarThru4, but there is no provision for faxes in this window - it also doesn't give me this model in the drop...
you should install the fax utility from SAMSUNG
got to the Software tab page and download the file :
PCFax_V1.05.13.exe
after restarting the pc it should work.
Jan 21, 2011 | Samsung SCX4623F Laser All-in-One Printer
HOLA ME SALE EL ERROR #02-000 EN LA SAMSUNG scx-4623f QUE PUEDO HACER
Nov 12, 2010 | Samsung SCX4623F Laser All-in-One Printer
Samsung SCX 4623F cannot scan even its already installed and connected to PC
Dear
Pl. down load and install the driver for scanner also the application smar thru you can also down load EDC (easy document creator0, after installing make repair on maintenance at program of pc.
Printer Support SAMSUNG India
Thanks.
Jul 17, 2010 | Samsung SCX-4300 Monochrome Laser...
How to reset toner ,Samsung SCX-4623F
we have reset software for scx 4623f printer. www.nakshatraworld.com
May 13, 2010 | Samsung SCX-4300 Monochrome Laser...
Samsung SCX4623F Laser All-in-One Printer Logo
405 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
