SOURCE: On my Sylvania 7" netbook from CVS (SYNET7WID-R).
Try to open the websites using Firefox. If you are already using firefox, try to reset it to default settings and try to open the websites again. If you don't want to use firefox, try to reset whichever browser you are using to default settings and try again.
You may also try clearing cache.
SOURCE: My Sylvania 7" netbook says;
If you have a SYNET07526, then you have a problem with loading all of your applications and it appears that I.E is a problem. You may want to re-flash your system as that is the only way you can get the full compliment of applications. See my TIP at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing
You may want to go to www.digitalgadgets and see if you can find the same information.
SOURCE: when the computer turns on
"Application explorer.exe encountered a serious error and must shut down"means sometime in the past, someone must have installed the OS incorrectly or has deleted something vital, which is why this error is occurring. The only way to bypass this is to reinstall windows OS using the CD that was provided for you, and this error will disappear.
SOURCE: When I startup my notebook it comes up with an
It sounds like there is an error in your hard drive.. that means some or all of the data in your hard drive has crashed. You have to go an IT support center to get it replaced/fixed.Please reply if you have any more questions. Good luck, Cooper. (Please give a thumbs up, I do this as a summer job!)
