When i try to send a message on my n95 8gb i get a failed message and then it says general memory full.close some applications and try again. what do i have to do to make it work please
hi, i cant send text messages. whaen i send it it always resend and when i resend it it becomes failed. and when i click the details it says that General memory full close some applications and try again later.. What can i do ?
YOU NEED TO CHANGE THE MESSAGING MEMORY BY FELLOW THIS TIPS : PRESS THE MENU AND PRESS MESSAGING AND PRESS OPTIONS CHOOSE SETTINGS CHOOSE OTHER CHOSE MEMORY IN USE THERE YOU CAN CHANGE THE PLACE THAT MESSAGE STORAGE IN .
sir your phone memory is full.empty your inbox and outbox and format your handset by using the following code *#7370#
it will require your phone lock code which is 12345 in default.
good luck
i have the same problem too. if you have solved this problem. pls pls pls send me some info. i would appreciate it very much. [email protected] ad me too in your ym.
Dial *#7370# from youre phone...enter the lock code, which generally is 1234...
it restores the phone completely...
Also, make sure that you save everything as back up because youll lose all your data when you restore your phone.It works.
GoodLuck.
