Question about Apex Digital LD4088 LCD TV
TV is in black and white when trying to play the XBOX 360. When it is on Direct Tv it works fine in color.
Posted by nmelerine on
Muntejaya Ginting
  • 10,422 Answers
May the current setting of your TV is NTSC and Just check your screen setting and bring to auto mode
Posted on Dec 25, 2010
1 Related Answer
Anonymous
  • 4 Answers
SOURCE: xbox 360 games are in black and white-recently
Take it back to the store its obviously defective
Posted on Jan 24, 2010
My Vision e500i-a1 will only play in black and white . Ideas ?
I have the same TV. My issue is if I hook a playstation 4 or Xbox one up to it, there is absolutely no color. My Xbox 360 works just fine on it though.
I have a daenyx lcd tv, model DN-15, input 12VDC-4A and am trying to hook it up to an xbox 360 console.
If you are using the Red/Yellow/White cable, that's composite cable, but if you're using the one that's Red/Yellow/White/Blue/Green, that's called component. So basically, you set your TV's input to the corresponding color match. 5 colors: Component, 3 colors: Composite.
Screen is black and white but plays fine
try a different tv set as it could be setting on you tv which is causing the black and white.
Xbox 360 plays movies fine but colour is wrong on games
i will suggest if you new tv has more inputs, just try a different imput, and make sure the plugs are in all the way. this is a new tv so it will be tight.
same with the video connection on the back of xbox well plugged and straigt.
hope this woks. and remember to rate me if i helped you
1helpful
Xbox 360 plays in black and white
Well, I have a couple of solutions that might work...
  1. Check your AV cables, it's possible that they could be the main problem (or try purchasing/borrowing a new cable to test with)
  2. Check your TV's settings, such as if it's NTSC or PAL (if the option exists) and it's colors.
If it's not the TV at all, then I'd say it's definitely #1 -- especially if it's a "Mad Katz" cable. Also, be sure that the AV cable is tight into the ports. One last suggestion would be to try a different TV. Hope this helps! Rob
My 360 when i start up it does everything in black and white
You can send your broken xbox 360 to my shop Fixit repair service and I can send you a refurbished xbox 360 system for $80 and one year warranty here is the number 206-271-0529
No Color
check the color and display settings on the 360 as well as the tv
3helpful
3answers
Xbox 360 black and white
I would check to make sure your video settings aren't set to PAL-60 by mistake. It might be easier to resolve if you could let us know what leads you have and where you've plugged them in to.
No color on Sony TV, all other tvs are great
check the av cables in back of your tv and also check the wires connected up to the xbox 60 it's self
Apex Digital LD4088 LCD TV Logo
Top Apex Digital Televison & Video Experts
Ekse
 Francisco Mauricio...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
